DIYnot
Local | Network
   DIYnot > Forums
Local | Network
Fixing a toilet to the floor
Post new topic   Reply to topic    DIYnot.com Forum Index > Plumbing and Central Heating
Author Message
andywatson
from United Kingdom
PostPosted: Thu Nov 30, 2006 7:55 pm Reply with quote
Well, as the title says, I need to secure a toilet to the floor. I was expecting this to be straightforwards, but when I came to attempt it I noticed the toilet has only 2 holes that look like they are for screws into the floor. Whilst that in itself isn't a problem, the fact that they are on a almost vertical part of the toilet is, as it appears there isn't an obvious route to the floor through these holes.
I am sure I have read that cement is not advised as it can crack the toilet.
How do I fit this toilet to the floor? Would a simple ring of silicon hold it in place?
Back to top
 Alert Moderators
sime10
from United Kingdom
Thanked: 6 times
PostPosted: Thu Nov 30, 2006 8:05 pm Reply with quote
No silicone on its own won't work
You should screw the pan, Yes it is difficult even for a plumber, Thats why we get paid to do things like this.
Is the pan upstairs or downstairs I do prefer to cement them down as it is permanent but if it has to be removed in the future you will lose the pan and have to replace.
Back to top
 Alert Moderators
GrahamT
from United Kingdom
PostPosted: Thu Nov 30, 2006 10:08 pm Reply with quote
Forget cementing it down!
For these types of pan use specific fixings kits (some made by Fischer)
They consist of 2 L-shaped plastic fittings that are fixed to the floor with coach bolts and then you fix through the holes in the pan to these fixings.
Sorry, hard to explain but go to any merchants - they'll know!
Back to top
 Alert Moderators
sime10
from United Kingdom
Thanked: 6 times
PostPosted: Thu Nov 30, 2006 10:34 pm Reply with quote
The fixings you are talking about are rubbish, plastic L shaped brackets
That are flexible and let the pan move.
Back to top
 Alert Moderators
steamvalve
from United Kingdom
PostPosted: Fri Dec 01, 2006 11:00 am Reply with quote
I've just done mine. I removed the toilet to tile the floor. When putting the toilet back I found the toilet base was not flat at all and wobbled about. So I bedded my toilet pan base onto a bed of wall tile adhesive to level it out (the most suitable thing I had to hand). This works great and if I have to remove in future the tile adhesive easily chips away from the ceramic finish (as it's designed to do). The pan is also screwed to the floor with brass screws at a slight angle. Finished off with a smooth silicon sealant strip. icon_biggrin.gif
Back to top
 Alert Moderators
andywatson
from United Kingdom
PostPosted: Fri Dec 01, 2006 12:12 pm Reply with quote
Thanks- I had a feeling there would be some kind of bolt I needed. I have also considered tiler adhesive to glue it down with (I have some left), but wondered if that would cause the same cracking as cement?
Out of interest, how do you use the timber?
Many thanks to everyone that's replied.
Andy
Back to top
 Alert Moderators
TicklyT
from United Kingdom
Thanked: 336 times
PostPosted: Sat Dec 02, 2006 7:44 am Reply with quote
I used a chunk of 4X2 cut to fit inside the void in the base of the pan, screwed the block to the floor, dropped the pan over it and put the screws into the sides of the block.
Back to top
 Alert Moderators
Nige F
from United Kingdom
Thanked: 847 times
PostPosted: Sat Dec 02, 2006 12:02 pm Reply with quote
..........cement/sand is OK.............It`s plaster/bonding that can crack a pan .......I know icon_redface.gif
Back to top
 Alert Moderators
Post new topic   Reply to topic    DIYnot.com Forum Index > Plumbing and Central Heating All times are GMT
Page 1 of 1
Jump to:
Fixing toilet pan to floor 3 1100 Sun Mar 30, 2008 4:41 pm
Fixing toilet to floor 4 160 Mon Nov 01, 2010 12:26 pm
Fixing a toilet to a wooden floor 3 320 Mon Oct 04, 2010 11:02 am
fixing toilet to floor 2 760 Sat Jul 01, 2006 5:49 am
Fixing Toilet To Floor?? 8 840 Sat May 24, 2008 6:26 pm
DIYnot
Please read our Privacy Policy. Copyright © 2000-2015 DIYnot Limited.
