I have leaking Croydex H2O Hydro-Powered Mixer Shower
30 Nov 2006
London
I believe many of Croydex H2O Hydro-Powered Mixer Showers have been problematic and it's been discontinued by the manufactuers.
Would anyone know of another mixer or thermostatic mixer out there with a distance of 60mm between hot and cold pipe centres. Then maybe I could remove my Croydex H2O Hydro-Powered Mixer Shower and push fit a replacement with the minimum of fuss.
Thanks in advance
skitey
You should only replace it with another venturi shower. there are only two on the market, the New Team Jetstream and the Treviboost. Check if your hot and cold pressures are compatible.
Hi, I have the same problem with my Croydex H2O Shower - it suddenly won't turn off... Any hints and tips as to how to fix it? Alternatively, any ideas of something that has the same/similar plumbing fittings??? As a last resort, what's the best bet for a shower running off a combi boiler? Cheers!
