DIYnot
Local | Network
   DIYnot > Forums
Local | Network
  Forum IndexForum Index     RulesRules    HelpHelp     Join FREERegister Free     BookmarksBookmarks     Watched TopicsWatched Topics     SearchSearch     LoginLogin
wiring double pole sockets
This topic originated from the How to page called Installing a power socket
Click here to return to the page called Installing a power socket.
  View previous topic :: View next topic
Author Message
IFH
from United Kingdom
Thanked: 0 times
PostPosted: Mon Dec 04, 2006 4:30 pm    Post Subject:
Reply with quote Thanks
I’m daisy chaining dual pole sockets. Normally, for single pole, I’d run the cables from terminal to terminal but I’m a little unsure as to how to add in the second earth terminal.
I assume that it’s permissible to just add a loop of (insulated) wire between the two earth terminals to connect the second one. I’m planning to use a piece of earth cable from flat twin and earth for the loop between the two earth terminals.
Am I correct in this. I hope my explanation is understandable. Any help and advice would be gratefully received.
IFH
Back to top
 Alert Moderators
If you don't want to see this advert, click here to login or if you are new click here to join free.
Steve
from United Kingdom
Thanked: 22 times
PostPosted: Mon Dec 04, 2006 4:34 pm    Post Subject:
AFAIK, the 2 earth terminals have an internal link anyway, so theres no need to connect them together. Just stick both earth wires into the one terminal.
I think you mean the ones where there is a metal strip running around the top of the socket, with an earth terminal on this strip, and one integral to the socket itself. You should be able to see where the metal strip tees off into the socket itself.
Back to top
 Alert Moderators
IFH
from United Kingdom
Thanked: 0 times
PostPosted: Mon Dec 04, 2006 5:24 pm    Post Subject:
Double pole sockets
Thanks, I'll take it from there.
IFH
Back to top
 Alert Moderators
Display posts from previous:
Page 1 of 1
Jump to:
wiring double pole sockets (2 earth terminals) 2 320 Tue Aug 19, 2008 1:12 pm
single vs double pole sockets 8 760 Wed Mar 15, 2006 10:13 am
Single pole or Double pole switches on sockets 4 580 Mon Dec 18, 2006 9:46 am
20A double pole switch wiring instructions please 2 500 Sat May 24, 2008 1:05 pm
Wiring up extractor fan without double pole FCU? 7 280 Sun Jun 29, 2008 3:32 pm
DIYnot
My DIYnot | Advertising | Newsletter
DIYnot.com | How to... | @home | Wiki | Forum
