DIYnot
Local | Network
   DIYnot > Forums
Local | Network
Jammed Mortice Lock
Post new topic   Reply to topic    DIYnot.com Forum Index > Windows and Doors
Author Message
chilluk
from United Kingdom
Thanked: 1 time
PostPosted: Wed Dec 06, 2006 8:12 am Reply with quote
My back door is locked shut and I can't turn the key - it feels like the lock mechanism is jammed tight - I can get the key in and turn in the direction that would lock it, but won't move a millimetre un the direction to unlock.
It's a mortice lock (with a chubb type key?) and the door is timer clad in aluminium.
Any ideas how to get it open so I can replace the mechanism?
Cheers.
Chris.
Back to top
 Alert Moderators
Diyisfun
from United Kingdom
Thanked: 210 times
PostPosted: Wed Dec 06, 2006 8:56 am Reply with quote
Have you tried spraying WD40 into the lock. Got to be the easy starting place.
Back to top
 Alert Moderators
JohnD
from United Kingdom
Thanked: 1439 times
PostPosted: Wed Dec 06, 2006 9:48 am Reply with quote
Good idea about trying to lube it.
Make absolutely sure that you are using the correct key.
Otherwise I think the lock is damaged. Make sure no vandal has poked anything through the keyhole.
If you are on the inside of the house, you will be able to cut the bolt of the lock without damaging the door or the frame much, as long as you can see the bolt in the gap.
You will have to use a padsaw or an angle grinder.
Once the door is open you can remove the lock fairly easily and throw it away with many curses.
I have only experienced this on cheap or very old locks, where the internal steel parts have rusted and broken.
I only use genuine Chubb 5-lever or detainer locks as the internal parts are in solid brass or substantial steel.
Back to top
 Alert Moderators
chilluk
from United Kingdom
Thanked: 1 time
PostPosted: Wed Dec 06, 2006 5:21 pm Reply with quote
Cheers for the replies. I will try and lube it although it feels more mechanically stuck that friction(ally) stuck.
It's a very thin gap between door and frame so not sure if can cut with anyything much!!
Cheers
Back to top
 Alert Moderators
big-all
from United Kingdom
Thanked: 935 times
PostPosted: Wed Dec 06, 2006 6:27 pm Reply with quote
another thing to try because the damp weather may have swolen the wood iiisss
lean hard on the door in the lock area to try and ease the sideways preasure
if its not tight try rattllng the door whilst turning the key to see if it helps
Back to top
 Alert Moderators
HandyHands
from United Kingdom
Thanked: 16 times
PostPosted: Thu Dec 07, 2006 12:02 pm Reply with quote
As Big-all suggests - check if the frame/door has swelled with the recent damp weather. It could be putting pressure on the bolt.
You don't state the lock make, or number of levers, but I'll assume it's a 5 lever BS rated model. likely problems are :
1. The lever pack has become gummed together, with the individual levers not returning to the correct position above the curtain. Try to "jiggle" the key as you turn it, as this may release the levers.
2. When you last locked/unlocked the door, the bolt didn't fully engage/return, and the lever pack is stuck in the unlock position with the bolt stump between the lever gates. Only way to resolve this is with a bent wire to manually move the bolt into it's correct position. If the lock is mounted on the Left (as you look at it), the bolt will be at the back of the lock. If its mounted on the right, then it will be at the front of the lock.
Going by your description, no.2 is the most likely.
Best option, with least amount of damage, would be to call a locksmith out.
Back to top
 Alert Moderators
joe-90
from United Kingdom
Thanked: 856 times
PostPosted: Thu Dec 07, 2006 12:19 pm Reply with quote
When frames are fitted they frequently have gaps at the sides. If you put a car jack across the frame and crank it you may get enough clearance to open the door, then you can replace the lock.
Even if you can't quite do that you may get better acces to the bolt to force it back with a sharp implement.
Back to top
 Alert Moderators
Post new topic   Reply to topic    DIYnot.com Forum Index > Windows and Doors All times are GMT
Page 1 of 1
Jump to:
Another jammed mortice lock! 4 200 Sat Jan 01, 2011 1:39 pm
Jammed/Broken Chubb Mortice Window Lock 2 700 Wed Sep 23, 2009 12:10 pm
jammed mortice lock 21 6500 Mon Feb 22, 2010 8:36 pm
Jammed lock on UPVC door 2 840 Fri May 04, 2007 1:16 pm
Help, My window handle is jammed in the lock position 4 100 Thu Feb 02, 2012 6:36 pm
DIYnot
Please read our Privacy Policy. Copyright © 2000-2015 DIYnot Limited.
