Hotpoint WM54 Prewash light flashing
6 Dec 2006
Worcestershire
Have read all posts regarding this machine but cannot find a solution..
When starting a mainwash the machine clears out the dispenser, starts rotating the drum and it sounds like its filling. Water is coming out of the waste pipe but there are only a few drops of water entering the drum. Eventually the prewash light starts flashing and nothing else happens.
Im thinking this could be a pump/blockage issue as the dispenser draw has recently started leaving deposits in the draw.
I didnt want to start stripping the thing to bits until I has a better idea of what might be at fault.
Any ideas guys?
Many Thanks
Alex
have you dad any luck fixing this problem, If so can you help me I have same problem. :(
check the waste pipe from the machine if it is lower than the drum it will syphon.
