DIYnot
Local | Network
   DIYnot > Forums
Local | Network
Flue fan replacement
Post new topic   Reply to topic    DIYnot.com Forum Index > Plumbing and Central Heating
Author Message
rpcvc
from United Kingdom
PostPosted: Thu Dec 07, 2006 11:50 pm Reply with quote
I have diagnosed the problem on my old Ferroli Popular FF77 combi as being fan failure on the flue. I have once got away with removing the flue and spraying the fan with WD40 to extend it's life, which it did by 2 years!
Tonight it has finally given up. Is it an easy/recommended job for someone who is mechanically experienced to change the fan and if any members can run me through it if they have previously done so i would appreciate any help. Getting cold now!
Back to top
 Alert Moderators
Blasphemous
from United Kingdom
Thanked: 15 times
PostPosted: Fri Dec 08, 2006 12:05 am Reply with quote
Yes, its an easy job for someone who is 'mechanically experienced'... but only a 'recommended' job for a Corgi icon_biggrin.gif
Joking aside rpcvc, the Flue Fan is Critical to remove the products of combustion from the combustion chamber. If its not done right and your case seals give then CO could spill into the room.
But someone else on here might advise you.
Back to top
 Alert Moderators
Slugbabydotcom
from United Kingdom
Thanked: 83 times
PostPosted: Fri Dec 08, 2006 12:16 am Reply with quote
If you are mechanically experienced then go for it. I cant say anything specifically related to that model as I haven't done one for a while but they aint rocket science.
Two years from a squirt of WD is a record I would say. The most I have had is about 10 months
A few points
Make sure the power is off. Obvious I know but I had to say it.
Get the Manufacturers instructions if possible. Ferroli will send a copy or .pdf version if you email them
Replace any damaged seals
Expect to remove and or replace the odd rusty screw.
Don't expect it to be too easy
Back to top
 Alert Moderators
rpcvc
from United Kingdom
PostPosted: Fri Dec 08, 2006 12:29 am Reply with quote
A few points
Many thanks for replies, found their website and will query them re instructions
Back to top
 Alert Moderators
Agile
from United Kingdom
Thanked: 3434 times
PostPosted: Fri Dec 08, 2006 12:49 am Reply with quote
It can be very dangerous using WD40 on boiler fans because the propellant is very flamable!
Motor car engine oil is safer and lasts several months in some cases whereas WD40 usually is for only a few days.
Tony
Back to top
 Alert Moderators
Slugbabydotcom
from United Kingdom
Thanked: 83 times
PostPosted: Fri Dec 08, 2006 1:02 am Reply with quote
Tony
It does save on barbers fees as Kevplumb and myself can both vouch for.
Mine was on a Glow worm swiftflow with a permanent pilot. Sprayed the fan. The butane propellant sank lower down in the boiler with being heavier than air, and Hey Presto! The quickest beard, nose hair and eyebrow trim I ever had in my life. I was wearing a baseball cap and the heat gathered under the peak giving me a rather sore 'sunburn'.
Back to top
 Alert Moderators
rpcvc
from United Kingdom
PostPosted: Fri Dec 08, 2006 8:55 am Reply with quote
I did turn off the gas before i did it!
Any plumbers/heating engineers in the Southport area on here?
Back to top
 Alert Moderators
Softus
from United Kingdom
Thanked: 9 times
PostPosted: Sat Dec 09, 2006 1:25 am Reply with quote
WD40 ?
Back to top
 Alert Moderators
Paul Barker
from United Kingdom
Thanked: 825 times
PostPosted: Sat Dec 09, 2006 9:52 am Reply with quote
I saved some young people and their carer in a hostel a fortnight ago from freezing over the weekend with cooking oil (because that's what they had at 23.00 on a Saturday night. I was highly surprised when I went back with new part that it was still working.
The thanks I got for turning out on a cold Saturday and using my witt and cunning to keep them warm was a disapproving snear from the guy who was on duty when I went to fit the fan, mumbling something about how there had been hell to pay because I wasn't an approved contractor (Government run organisation). I bet there approved contractor won't be available 23.00 on a Saturday night out of the kindness of his heart in the future either.
I was hardly going to charge, because I totally believe in helping the homeless, but now that they have been all arsy and it's government money anyway I'm going to stick them up with a late night call out, retail price on the fan and second call out for going to fit it.
Back to top
 Alert Moderators
Post new topic   Reply to topic    DIYnot.com Forum Index > Plumbing and Central Heating All times are GMT
Page 1 of 1
Jump to:
Potterton Kingfisher II RS80 Flue Replacement 9 200 Fri Jan 28, 2011 8:50 pm
Baxi boiler flue 6 240 Fri Apr 08, 2011 5:41 pm
Vaillant Turbomax 828 flue problem 5 140 Wed Apr 13, 2011 3:52 pm
Boiler Flue Extension 26 4820 Tue Apr 26, 2011 9:15 am
Existing flue question 12 320 Sat Apr 30, 2011 5:52 pm
DIYnot
Please read our Privacy Policy. Copyright © 2000-2015 DIYnot Limited.
