DIYnot
Local | Network
   DIYnot > Forums
Local | Network
Light fitting with two earth wires
Author Message
mark_a
from United Kingdom
PostPosted: Fri Dec 08, 2006 9:19 am Reply with quote
Hi folks, I just bought a (metal) light fitting that has a central 3 core wire connection and a shorter seperate earth connection. I have not seen two earth wires like this before. I was planning on doing the electrical connection in the floor space above the chandelier as there isn't much room underneath the fitting because of a plaster ceiling rose so how do I connect the 2nd earth wire? Do I extend it up into the floor space and connect it to the single incoming earth? or is it even required it there is already a central earth?
Mark
Back to top
 Alert Moderators
ch427
from United Kingdom
Thanked: 236 times
PostPosted: Fri Dec 08, 2006 10:09 am Reply with quote
is it lead that attatches to a removable cover?
Back to top
 Alert Moderators
DESL
from United Kingdom
PostPosted: Fri Dec 08, 2006 12:35 pm Reply with quote
You need to connect any exposed metal work of the fitting to the earth of the circuit using the earth wire fitted to the body, even though the flex has an earth core.
This will prevent the metal fitting becoming live under fault conditions.
Back to top
 Alert Moderators
tim west
from United Kingdom
Thanked: 8 times
PostPosted: Fri Dec 08, 2006 1:10 pm Reply with quote
It may be that the lampholder(s) does not have a sufficient electrical earth connection to the main body of the lamp and the fly earth lead is to make sure the main body is earthed to the same potential as the lampholder bodie(s)? so just make sure the earths are connected together to the lighting earth.
Back to top
 Alert Moderators
mark_a
from United Kingdom
PostPosted: Fri Dec 08, 2006 2:58 pm Reply with quote
Thanks for the responses. I will extend the earth up and connect it along with the other earth to the main connection. Perhaps the manufacturer was being overcautious thinking the metal chain links connecting the ceiling end of the light with body holding the lamp holders could be broken somehow! Looking forward to lifting the floorboards in the room above to assess the diy workmanship as the main cable coming down is gold plastic and not the usual white or grey!!
Back to top
 Alert Moderators
Steve
from United Kingdom
Thanked: 226 times
PostPosted: Fri Dec 08, 2006 9:00 pm Reply with quote
You dont know what you're talking about. The body of the lamp needs earthing because it isn't double insulated and is metal. There is therefore a chance that the body could become live during a fault and kill someone.
Nothing to do with lampholders. These, generally, aren't earthed, since light bulbs dont need an earth last time i looked.
Back to top
 Alert Moderators
Steve
from United Kingdom
Thanked: 226 times
PostPosted: Fri Dec 08, 2006 9:03 pm Reply with quote
oh dear god. sounds like a shoddy DIY install.
The manufacturer is not being over cautious, they are fulfilling a requirement that nobody dies by touching their appliance during a fault. Many light fittings come with an earth flylead attached to the metal body. Its nothing unusual. And a chain cannot be relied upon for electrical continuity - there would be plenty of resistance even when pulled tight.
Back to top
 Alert Moderators
ricicle
from United Kingdom
Thanked: 382 times
PostPosted: Fri Dec 08, 2006 9:10 pm Reply with quote
Back to top
 Alert Moderators
Steve
from United Kingdom
Thanked: 226 times
PostPosted: Fri Dec 08, 2006 9:45 pm Reply with quote
ricicle wrote:
But the lampholders on most light fittings are integral to the metalwork on the fitting. icon_wink.gif
Back to top
 Alert Moderators
Page 1 of 1
Jump to:
Two earth wires - fitting new pendent light - help! 17 280 Tue Mar 04, 2014 7:40 pm
light fitting with loads of wires 12 760 Tue May 27, 2008 1:17 pm
Installing a ceiling light fitting, Help! Stumped by wires! 20 2740 Thu Jun 05, 2008 7:09 pm
Light fitting - What to do with the loop wires? 6 33360 Sun May 18, 2008 3:30 pm
Help New light fitting - extra wires 11 280 Sun Jul 28, 2013 12:21 pm
DIYnot
Please read our Privacy Policy. Copyright © 2000-2015 DIYnot Limited.
