low pressure - cold showers
7 Dec 2006
Manchester
I have a Triton Opal shower that was installed about 2 years ago. It was working fine - powerful and hot and then suddenly the water pressure seems to have reduced and the shower light for \\\"low pressure\\\" shows and it runs cold. We live in a flat and the shower is run from the mains cold water supply. I note the above comments about my model of shower and installing pumps, but just wanted to check everything before going to the expense of buying a new shower etc.
Sorry, I thought you could read our minds.
Do you think it's the shower unit that needs replacing, or do you think I just need to have a pump fitted? Or alternatively, would you recommend just getting one of those showers with the built in pump designed for low water pressure?
Shower feed may be blocked. Worth undoing and checking the inlet filter.
Whats the pressure like at the taps?
Wow - I have the same problem with my Opal shower, sometimes on sometimes 'low pressure' light. Have you managed to fix it or did you have to buy a new shower. My Mother-in law is coming for Christmas and I need a shower for then.
Are you sure these are on the mains? If so, you can't pump it.
Why don't you ring the Triton customer service department. They are extremely helpful. Your shower might still be under guarantee.
