DIYnot
Local | Network
   DIYnot > Forums
Local | Network
  Forum IndexForum Index     RulesRules    HelpHelp     Join FREERegister Free     BookmarksBookmarks     Watched TopicsWatched Topics     SearchSearch     LoginLogin
Firring new toilet to soil pipe
This topic originated from the How to page called Drainage Systems
Click here to return to the page called Drainage Systems.
Post new topic   Reply to topic    DIYnot.com Forum Index > Plumbing and Central Heating
  View previous topic :: View next topic
Author Message
Scankguy
from United Kingdom
Thanked: 0 times
PostPosted: Fri Dec 15, 2006 8:19 pm    Post Subject:
Reply with quote Thanks
I saw a post from last year - same question as mine but not sure it was answered. How do you get a new loo (Thames Modern Compact) to fit an old loo position soil pipe??
I have an old house with a downstairs bathroom. The soil pipe goes down into the concrete floor. The existing loo cistern I am removing is spaced away from the wall with some 2x4.
The new loo cistern sits on the loo body, and does not screw into the wall, being designed to be just off the wall, but does look silly 6 inches away ...and wont look nice boxed in although I suppose I could dry line the wall out to meet the loo with a shelf on top....
I have just bought a low profile 90 degree pan conector ? shape, but the cistern is still 4inches away and the pipe look like it would foul the loo base.
Would it be OK to put two 90 degree bends together and into the pan connector turned back towards the wall and with the loo to the side? I imagine this will block ...or how safe are those flexible connectors?
Any suggestions please. (sorry lots of words but I konw how you like detail...)
Cheers
Back to top
 Alert Moderators
If you don't want to see this advert, click here to login or if you are new click here to join free.
howy1
from United Kingdom
Thanked: 0 times
PostPosted: Fri Dec 15, 2006 9:21 pm    Post Subject:
IF you are into a little bit of work , you could check if the soil pipe from the pan runs straight out underground to a manhole , if it does you will have to dig down to the 4" pipe cut it to allow for a 90 degree bend to come up the outside of the house . The pipe from the pan would then go straight through the wall 90 degree bend down to meet bend coming up, fill exsisting hole in floor screw pan on wall nice and neat , job done .
Back to top
 Alert Moderators
Scankguy
from United Kingdom
Thanked: 0 times
PostPosted: Fri Dec 15, 2006 11:55 pm    Post Subject:
Unfortunately not, it goes down about 3 feet then turns towards the manhole and under the foundations....
Thanks for the suggestion though
Back to top
 Alert Moderators
sime10
from United Kingdom
Thanked: 0 times
PostPosted: Sat Dec 16, 2006 12:00 am    Post Subject:
Dig up and alter only way out
__________________
You live to learn and Learn to live
Back to top
 Alert Moderators
Display posts from previous:
Post new topic   Reply to topic    DIYnot.com Forum Index > Plumbing and Central Heating All times are GMT
Page 1 of 1
Jump to:
caping of a toilet soil pipe 4 360 Sat Jan 27, 2007 11:58 am
New toilet and soil pipe 3 4280 Wed Jan 10, 2007 3:05 pm
Toilet Soil Pipe 10 720 Sun Sep 24, 2006 11:55 am
toilet connection to soil pipe outside 3 660 Sat Jan 27, 2007 1:21 pm
Toilet soil pipe location. 5 500 Sun Apr 22, 2007 4:13 pm
DIYnot
My DIYnot | Advertising | Newsletter
DIYnot.com | How to... | @home | Wiki | Forum
