DIYnot
Local | Network
   DIYnot > Forums
Local | Network
  Forum IndexForum Index     RulesRules    HelpHelp     Join FREERegister Free     BookmarksBookmarks     Watched TopicsWatched Topics     SearchSearch     LoginLogin
Red Brick Dust
This topic originated from the How to page called Domestic Items
Click here to return to the page called Domestic Items.
Post new topic   Reply to topic    DIYnot.com Forum Index > General DIY
  View previous topic :: View next topic
Author Message
Tek
from United Kingdom
Thanked: 0 times
PostPosted: Sat Dec 16, 2006 4:17 pm    Post Subject:
Red Brick Dust
Reply with quote Thanks
Could anyone tell me how to remove red brick dust stains from a beige carpet please?
Back to top
 Alert Moderators
If you don't want to see this advert, click here to login or if you are new click here to join free.
joe-90
from United Kingdom
Thanked: 57 times
PostPosted: Sat Dec 16, 2006 5:07 pm    Post Subject:
With a vacuum - don't wet it.
Back to top
 Alert Moderators
Tek
from United Kingdom
Thanked: 0 times
PostPosted: Sun Dec 17, 2006 11:40 am    Post Subject:
Thanks for the reply. I tried that as soon as it happened but the red staining has remained. There does not seem to be any dust left, just the stain. This has never been a problem before as it normally comes up with a vacuum cleaner, the carpet is only a couple of days old and the dust slipped by the dust sheet.
Back to top
 Alert Moderators
sidecar_jon
from United Kingdom
Thanked: 0 times
PostPosted: Sun Dec 17, 2006 8:00 pm    Post Subject:
Maybe sprinkle talc on it then vac it up.
Back to top
 Alert Moderators
sterling
from United Kingdom
Thanked: 0 times
PostPosted: Mon Dec 18, 2006 11:33 pm    Post Subject:
general DIY
Had the same problem.
Get a spray can of 1001 Spot remover.
Ignore the instructions on the side of the can, and soak the affected area with this spray, then make sure you have a wet and dry vacuum, NOT A NORMAL VACUUM CLEANER, it HAS to be a wet and dry.
Let it soak in for a couple of minutes, then vacuum up, you may have to do this several times.
The cans of spray cost about £5.00.
It has worked for me on several occasions, best of luck.
Mike
Back to top
 Alert Moderators
Tek
from United Kingdom
Thanked: 0 times
PostPosted: Sat Dec 23, 2006 12:49 pm    Post Subject:
Thanks I will have to get hold of a wet and dry vacuum cleaner!
Back to top
 Alert Moderators
Display posts from previous:
Post new topic   Reply to topic    DIYnot.com Forum Index > General DIY All times are GMT
Page 1 of 1
Jump to:
Concrete Dust 4 740 Wed Dec 07, 2005 10:27 am
Best way & tool to clean builders mess/dust etc? 3 460 Fri Aug 24, 2007 9:17 pm
Which Dust Mask? 5 440 Sun Dec 05, 2004 8:36 pm
Flaking paint on the wall in conservatory? White dust there? 2 340 Mon Oct 13, 2008 3:46 pm
Best Dust Sheets 7 560 Fri Jun 12, 2009 4:14 pm
DIYnot
My DIYnot | Advertising | Newsletter
DIYnot.com | How to... | @home | Wiki | Forum
