DIYnot
Local | Network
   DIYnot > Forums
Local | Network
  Forum IndexForum Index     RulesRules    HelpHelp     Join FREERegister Free     BookmarksBookmarks     Watched TopicsWatched Topics     SearchSearch     LoginLogin
Question regarding earth when installing two single sockets
This topic originated from the How to page called Installing a power socket
Click here to return to the page called Installing a power socket.
  View previous topic :: View next topic
Author Message
milmber
from United Kingdom
Thanked: 0 times
PostPosted: Sun Dec 17, 2006 3:12 pm    Post Subject:
Reply with quote Thanks
Hi, I have a question regarding earth when installing two single sockets. I have installed the first socket successfully, but for the second I notice that there is only a live and neutral ( i.e. no seperate earth wire ). Can I simply connect the earth to the first socket's earth wire?
Back to top
 Alert Moderators
If you don't want to see this advert, click here to login or if you are new click here to join free.
Spark123
from United Kingdom
Thanked: 39 times
PostPosted: Sun Dec 17, 2006 3:15 pm    Post Subject:
I don't follow, there should be an earth at the socket unless it is installed in old conduit or similar?
Back to top
 Alert Moderators
milmber
from United Kingdom
Thanked: 0 times
PostPosted: Sun Dec 17, 2006 3:21 pm    Post Subject:
Sorry. Best I explain a bit better. There were two seperate faceplates next to each other. One contained a connection for a washing machine (which I turned into a standard single socket). The other faceplate, sharing the same recess, was just a cover with no socket.
Both these faceplates share the same socket recess, with only 5 wires instead of 6 from the mains. I.e.:
live 1
neutral 1
earth 1
live 2
neutral 1
Back to top
 Alert Moderators
Spark123
from United Kingdom
Thanked: 39 times
PostPosted: Sun Dec 17, 2006 3:24 pm    Post Subject:
Can you post a picture:
To upload an image;
Go to a hosting site such as imageshack: http://imageshack.us/
Click browse and locate the image. Ensure resize image is ticked and select 640 x 480 (for message boards). Click host it.
After the image has uploaded imageshack displays a list of links to the image. Highlight the text in the line at the bottom of the screen "direct link to image" and copy the text (press CTRL C to copy).
On your post type [img][/img] and insert the text from imageshack inbetween the two (press CTRL V to paste), so it reads something like:
[img]http://img404.imageshack.us/img404/4848/dolrwo4.jpg[/img]
When you submit your post the image should now appear.
Back to top
 Alert Moderators
sparkybird
from United Kingdom
Thanked: 2 times
Hmm, sounds a bit odd?
Are there two white or grey cables with each of the live/neutral/earth coming out of them? If so, maybe the missing earth has been chopped off short. You might be able to strip back the pvc sheathing to find it...
SB
Back to top
 Alert Moderators
milmber
from United Kingdom
Thanked: 0 times
PostPosted: Sun Dec 17, 2006 3:37 pm    Post Subject:
Back to top
 Alert Moderators
Spark123
from United Kingdom
Thanked: 39 times
PostPosted: Sun Dec 17, 2006 3:41 pm    Post Subject:
Idea, have they shoved both earth wires into the one sleeve? I can't see a grommet there in the hole either icon_evil.gif .
My only concern there is that both of the cables appear to be different sizes, what is the smaller one for?
Back to top
 Alert Moderators
milmber
from United Kingdom
Thanked: 0 times
PostPosted: Sun Dec 17, 2006 3:42 pm    Post Subject:
Hi, yes, the second set of neutral and live cables does seem to be thinner than the first.
Back to top
 Alert Moderators
Spark123
from United Kingdom
Thanked: 39 times
PostPosted: Sun Dec 17, 2006 3:47 pm    Post Subject:
Are they connected to anything, given there was only a blank there before? Could it be meant for a fused spur unit? The cables that are supplying the socket look quite a lot bit bigger, what size fuse/mcb is supplying it?
Back to top
 Alert Moderators
milmber
from United Kingdom
Thanked: 0 times
PostPosted: Sun Dec 17, 2006 3:51 pm    Post Subject:
Not 100% sure, but I suspect that the cables supplied a boiler ( which has been moved ) or washing machine. To tell you the truth I'm only confident up to the point where I see neutral, live and earth. Anything more is out of my league.
I figure I'm going to have to have a proper electrician look at this.
Thank you for the help and quick replies.
Back to top
 Alert Moderators
uug197h
from United Kingdom
Thanked: 0 times
PostPosted: Sun Dec 17, 2006 5:44 pm    Post Subject:
Re: Question regarding earth when installing two single sock
this should be a ring main put the other wires in the same connections EG:-live to Live this will complete the circuit
Back to top
 Alert Moderators
RF Lighting
from United Kingdom
Thanked: 73 times
PostPosted: Sun Dec 17, 2006 5:50 pm    Post Subject:
WTF?
That is very very very bad advice.
We do not know anywhere near enough about this setup to be making stupid suggestions like that.
If it were a ring then the set of cables which are not connected to anything would already be live, and this still doesent explain the missing earth.
__________________
I downlights
Back to top
 Alert Moderators
festa
from United Kingdom
Thanked: 0 times
PostPosted: Sun Dec 17, 2006 7:35 pm    Post Subject:
Yep as mentioned by RF above, DONT connect those sets of wires together.
You MUST get a profesional electrician in,as a number of things can be going on here and only proper testing will show the truth.
My opinions are
1) If the socket is on a radial,then at one time there may have been a fused connection unit where the now blank plate is sited ,that fed the thinner wire.
2)You may indeed have the socket connected to a ring circuit but your socket is either a spur or it is supplied by a junction box under the floor boards and as above there was once an FCU where the blank plate is now.
3)The FCU (if there was one there),was supplying EQUIPMENT that was SELV and the `electrician` who wired it up has chopped back the earth in the thinner wire so it wasnt connected by mistake (ive come across this in lighting circuits and its bad practice but not un-common).
4)Worst case is someone has tried turning an old radial circuit into a ring and has completed the ring in a thinner wire than the radial (which will show if you look at the wires going into the top of the fuse/mcb protecting your socket circuit,I.E one thick wire and one smaller one )
Back to top
 Alert Moderators
securespark
from United Kingdom
Thanked: 14 times
PostPosted: Sun Dec 17, 2006 9:57 pm    Post Subject:
Whatever it was, it looks like the 2,5 was the feed, and the 1,0 was the outgoing circuit. As already advised, check to see if you can find the origin of the 2,5 and destination of the 1,0.
__________________
As George Michael once said, "..if you're gonna do it, do it right, right?"
Back to top
 Alert Moderators
Display posts from previous:
Page 1 of 1
Jump to:
Installing 2 * 2 gang sockets in place of a single socket 19 580 Sun Oct 04, 2009 3:00 pm
Installing two ovens on a single circuit 3 180 Mon Jun 22, 2009 11:16 pm
Installing a single oven 10 3960 Fri Nov 25, 2005 7:23 am
Best practice ? installing single electric oven and hob 12 1860 Sat Jan 21, 2006 2:44 pm
installing a built in single electric oven 7 4800 Fri Mar 09, 2007 9:04 pm
DIYnot
My DIYnot | Advertising | Newsletter
DIYnot.com | How to... | @home | Wiki | Forum
