potterton profile 60e LPG
It does sound like the aps is switching alot, but I've already had this checked out and replaced.
Don't think the pilot should stay on if its the fan or aps
If the pilot is staying on then the fan must also continue to run which meens it is not the stat or aps, the most likely cause is the solenoid on the gas valve dropping out.
Pressure switch, pcb or a poorly running fan.
if the aps fails on this boiler I t WILL light even without the fan
