Joined: 06 Oct 2004 Posts: 1052 Location: United Kingdom Thanked: 0 times
Posted: Tue Dec 19, 2006 9:20 am Post Subject:
I thought these were made of pre cast concrete blocks with a pebble dash on the outer surface. Are we talking about the same thing ? If so, why do you want to render on that ?
Joined: 18 Dec 2006 Posts: 2 Location: Lincolnshire, United Kingdom Thanked: 0 times
Posted: Tue Dec 19, 2006 4:46 pm Post Subject:
airey house
My airey house is constructed of precast concrete slabs stacked horizontaley so there is a kind of step effect i wanted to make the wall smoth so i could pebal dash the bottom half and smooth painted finish top half if that makes any sence .
Joined: 08 Jun 2007 Posts: 3 Location: Northamptonshire, United Kingdom Thanked: 0 times
Posted: Fri Jun 08, 2007 2:50 pm Post Subject:
airey house
Why do you want to render it, we have one and are debating bricking it up to increase value and morgagability. How much do you know about the construction of Airey houses and the reason for them being on the 'defective dwelling' list, we have found getting info difficult but have got some from the council at last
Posted: Wed Jun 13, 2007 9:07 am Post Subject:
conplus wrote:
i work on the Airey house all the time if you need to know anything then let me know
we have an Airey which we purchased years ago and the council gave a notice that it was defective but the problem had been overcome by works that they did. we now realise that the work they did did not make it a non defective property and are trying to decided what to do with it and how much investment we should make in it. It was ring beamed years ago by the council as the concrete column bottoms were cracking. am i right in thinking that this might just delay the problems in the concrete columns but not fix it. we have also noticed cracking in one of the window mullions. any info would be great as if we decided to brick this house up it will cost thousands of pounds
Joined: 12 Jun 2007 Posts: 2 Location: Wiltshire, United Kingdom Thanked: 0 times
Posted: Sun Jul 08, 2007 9:07 pm Post Subject:
if you want a mortgage on this house then the coloumns need to be removed and then bricked up, this needs to be done under a licence eg Adam s Consulting engineers from mold
Joined: 28 Jun 2005 Posts: 7494 Location: United Kingdom Thanked: 31 times
Posted: Thu Jul 12, 2007 4:35 pm Post Subject:
Seriously........IF you and any neighbours can get together and sell a block of these houses for re-development.........as Brownfield .....then GO for it There is an obvious trend here in Sussex at least ....1Bungalow down 2pairs of semis up........another 1 rotten bungalow and a nonedescript detached down 2 pair of (nice) semi`s up..honestly guys, it`s THE way forward.....the gardens on the new replacements are non-existant but they`re up +sold
Posted: Tue Mar 18, 2008 8:38 pm Post Subject:
I have found finding info on airey houses hard. I would like to say i've found a new forum just set up it's well worth a visit hope this helps. www.aireyhouse.your-talk.com
I have recently bought my airey construction house.It was repaired/modernised around 10yr ago.They replaced the concrete columns with a steel frame.This is apparently structually sound for at least the next 30 yr.However, very recently cracks have started to appear in the plaster boards,seemingly at the joins(im guessing)I have 2 cracks from wall to wall on the ceiling,in a straight line.A few around door caseings,and on walls again, all straight lines.I also have about 5 around the windows (on the wall)at the bottom corners.These seem to have appeared during the cold weather,although I did have 1 around 2 yr ago.
Can anybody help?are these cracks anything to worry about?
hi I just wondered if you have actually got around to bricking up your house?Im in the same position and considering my options.
Distressed lady; sorry I can't help with your problem but can I point out your actually posting on a thread from 2006 & on which the last post was nearly a year ago ! I know it can be difficult spotting the dates if you’re new to the forum but if you start a new thread of your own you will probably have a better response.
You cannot post new topics in this forum You cannot reply to topics in this forum You cannot edit your posts in this forum You cannot delete your posts in this forum You cannot vote in polls in this forum
