The title says it all. I cannot control the hot water system (boiler and cylinder type) without the central heating coming on (and vice versa). I assume this is due to a seized (due to sludge) electric splitter valve (sorry but I don't know the correct term). If I wanted to replace it would I need to drain the whole system, just the cylinder or something else?
When I replace it I plan to install valves on its output side (one to the CH and another to the HW). Is this ok? I'm just thinking about potential problems: if after fitting, both new valves were closed and the HW and CH were switched on, what would happen?
Thanks.
Thanks.
