Joined: 20 Dec 2006 Posts: 18 Location: Avon, United Kingdom Thanked: 0 times
Posted: Wed Dec 20, 2006 3:59 pm Post Subject:
COOKER AND HOB WIRING
Hi, im just after a bit of advice please,im just about to rip out and fit a new kitchen,i`ve bought a new electric double oven and electric hob,i have a cooker socket with a 10mm cable,the instulation book for the cooker says to use a 2.5mm cable and the hob is 6mm cable.What i want to do is fit the cooker next to the cooker socket and the hob on a sort of island unit in the middle of the room so what i want to know is would it be safe to run a 6mm cable behind the back of the kichen units to the hob? ,it would probably need about 4 metres of cable to do this although the hob would still only be about 2 metres from the cooker socket , any advice anyone cheers.
Posted: Wed Dec 20, 2006 9:10 pm Post Subject:
I have a cooker isolation switch on the wall then under that i have the junction box where my old cooker is connected to at the moment so im thinking the easy way would be to connect both the cooker and the hob to that junction box but then run the 6mm cable posibly armcore cable around the back of the new kitchen units out of site to the hob on the island ,is that ok ? or would i have to run a new cable from the main house junction box to a new isolation switch near to the hob ,trouble is its quite a new house with those stupid slot together floor boards and fitted carpets so i dont really want to spend xmas ripping up that lot as well as the kitchen ,is there a easy way of doing this, cheers
Posted: Thu Dec 21, 2006 8:13 am Post Subject:
So as long as the hob is not more than 2 metres from the switch then thats ok ,it wont be a problem with the cable being longer than 2 metres will it , my kitchen units are like a U shape with the switch and junction box at one end of the U and the hob at the other end of the U and the 6mm cable running around the U from junction box to hob ,is that ok to do that thanks
Joined: 27 Jul 2006 Posts: 4931 Location: Oxfordshire, United Kingdom Thanked: 63 times
Posted: Thu Dec 21, 2006 6:30 pm Post Subject:
You OK with that. The 2 metre thing is so that, in the event of a problem (fire, etc) the isolation switch is accessible and close enough so u can click her off..
Posted: Thu Dec 21, 2006 7:41 pm Post Subject:
Thanks for that ttc i understand now, im going to fit the kitchen myself and get a electrician in to do the wiring as i understand i cant do it myself but i thought i could route the cable for the hob myself and let him connect it for me to save some money ,but wanted some advice first because its easier to route the cable now with the old kitchen ripped out, so all i have to do is run a cable from my cooker junction box around to where the new hobs going to be is it and in the hob instuctions book it says to use 6mm cable ,does that sound right , cheers mate
You cannot post new topics in this forum You cannot reply to topics in this forum You cannot edit your posts in this forum You cannot delete your posts in this forum You cannot vote in polls in this forum
