Miah,
You're not looking for a specially made pipe, what I'm saying is the layout of some pipe work is such that an inverted 'U' is formed and when a system has been drained and is being refilled air can get trapped because it can't escape even when the pump is running. This is because the air is compressible and the pump is not powerful enough to deal with it because there is too much resistance to flow. Pockets of air in radiators are catered for by bleed valves and bleed valves can also be incorporated in a system if a air pocket/lock is likely. Most systems avoid having the inverted 'U' and those that don't rely on the pump to push any air to the radiators where in can be bled off.
Brakes on a car with a hydraulic system have a similar problem, if air gets in, the brakes become ineffective because the full pressure can't be applied.
The pump on a central heating system should be able to move the water around the pipe work without any great resistance and if it does not it is due to either.
pump not running
pump running in a air pocket and needs bleeding
sludge in pipe work preventing the water to flow
air pocket in pipe work preventing the water to flow
mid position valve (if fitted)not functioning
An air pocket in a radiator should not stop the flow of water around the pipe work supplying the radiators.
MW,
If there is no air or water coming from a radiator valve which is known to be open then I would suspect sludge causing a blockage but I would verify the pump is running and has been bled.
