Indesit WN1096WG not emptying properly
21 Dec 2006
Sheffield
my machine which I've just installed in my new house is not emptying properly. What happens is that it doesn't appear to get rid of the waste water and it just keeps filling up until water starts pouring out of the powder drawer, the waste pipe is not blocked, and it is connected to the underneath of the sink. It connects into a screw type fitting which is angled upwards at about 45 degrees. It's about 60-70cm off the ground. If I switch the machine off after it has started spewing out water, unscrew the waste pipe and hold it low down then all the water will come out then (woo gravity!). Any ideas would be appreciated, I'm sure I have hooked it up the same as it was in the last house...
Pressure chamber blocked, pressure hose holed or off or pressure switch faulty.
