DIYnot
Local | Network
   DIYnot > Forums
Local | Network
  Forum IndexForum Index     RulesRules    HelpHelp     Join FREERegister Free     BookmarksBookmarks     Watched TopicsWatched Topics     SearchSearch     LoginLogin
how many bends??
This topic originated from the How to page called Drainage Systems
Click here to return to the page called Drainage Systems.
Goto page 1, 2  Next
Post new topic   Reply to topic    DIYnot.com Forum Index > Plumbing and Central Heating
  View previous topic :: View next topic
Author Message
radio1
from Spain
Thanked: 0 times
PostPosted: Thu Dec 21, 2006 10:36 pm    Post Subject:
how many bends??
Reply with quote Thanks
Hi ,, I want to install a new bathroom i.e toilet, bath,and washhand basin,in the top of the house using 110mm plastic waste pipe for the toilet and 50mm pipe for waste sink water.
In order to do this I will need to fit 8 x 90 deg bends, A guy who lives near by told me I cant use any more then 3 x 90 deg bends in any 3 meter lengh of 110mm pipe ,,, is this right??
any help would be nice please.
regards
Back to top
 Alert Moderators
If you don't want to see this advert, click here to login or if you are new click here to join free.
bster
from United Kingdom
Thanked: 0 times
PostPosted: Thu Dec 21, 2006 10:44 pm    Post Subject:
if basin is'nt teeing into the shower or bath waste then 32mm will be fine (depending on length).
Which pipe are the bends going to be on?
__________________
I am newly qualified, so don't rely on my advice get a second opinion!!!
Back to top
 Alert Moderators
Agile
from United Kingdom
Thanked: 191 times
PostPosted: Thu Dec 21, 2006 10:57 pm    Post Subject:
Read the question bster!
I think he is ( mostly ) talking about using a lot of elbows on the 110 mm !
I dont think there is any hard and fast rule apart from common sense which is only gained by experience of things which dont work! DIYers often sem to think that as long as you can string them together then they must work. The real world is different!
Tony
Back to top
 Alert Moderators
Blasphemous
from United Kingdom
Thanked: 20 times
PostPosted: Fri Dec 22, 2006 12:29 am    Post Subject:
So are you saying you need to use Eight 90 Deg Bends in 3meters of pipework? What the hell are you trying to get the pipework around that requires that many bends?!?!? icon_eek.gif
Back to top
 Alert Moderators
Nige F
from United Kingdom
Thanked: 31 times
PostPosted: Fri Dec 22, 2006 9:37 am    Post Subject:
long as your stools are soft you`ll be ok icon_lol.gif icon_lol.gif icon_lol.gif
Back to top
 Alert Moderators
radio1
from Spain
Thanked: 0 times
PostPosted: Fri Dec 22, 2006 6:00 pm    Post Subject:
will this help you??
OK the first bend will be from the toilet plus 500mm of 110 pipe, next bend throu the wall into the next room, when it goes throu this wall it needs to bend again as the main wall is about 400mm away, then it need to bend again to go around a pier which is 500mm x 300mm then it will run for about 2700mm then go round the other pier then throu the floor dropping to the ground . hope this will help a bit better.
regards
mike
Back to top
 Alert Moderators
Bahco
from United Kingdom
Thanked: 5 times
PostPosted: Fri Dec 22, 2006 6:10 pm    Post Subject:
I think your only concern should be blockages which shouldn't happen if you get the correct fall.
__________________
85 weeks without smoking!
Back to top
 Alert Moderators
holty
from United Kingdom
Thanked: 21 times
PostPosted: Fri Dec 22, 2006 8:35 pm    Post Subject:
at least 2x 45degrees, for a 90, with rodding points if your attempting this.
Back to top
 Alert Moderators
libby lou lou
from United Kingdom
Thanked: 1 time
PostPosted: Fri Dec 22, 2006 9:21 pm    Post Subject:
If it will go round the first bend without a problem, why does it not go round the 21st bend without a problem ? i'm not a plumber, but would like to know the reason. thanks
Back to top
 Alert Moderators
Nige F
from United Kingdom
Thanked: 31 times
PostPosted: Fri Dec 22, 2006 9:36 pm    Post Subject:
well the principle that keeps a 1920`s Indian on the Wall of Death can cause a Richard 111 to stick icon_eek.gif icon_lol.gif icon_lol.gif (Indian v twin motorcycle)
Back to top
 Alert Moderators
dan the man
from United Kingdom
Thanked: 0 times
PostPosted: Sat Dec 23, 2006 9:49 am    Post Subject:
just loses momentum. our turds dont have VTEC past a certain amount of bends icon_lol.gif
Back to top
 Alert Moderators
Agile
from United Kingdom
Thanked: 191 times
PostPosted: Sat Dec 23, 2006 10:56 am    Post Subject:
The standard fall of 1:40 allows a certain flow velocity. Every change of direction will slow this down.
I have a recollection that you can reset the velocity by using a short vertical section if this is available within the space available.
Tony
Back to top
 Alert Moderators
Paul Barker
from United Kingdom
Thanked: 18 times
PostPosted: Sat Dec 23, 2006 1:14 pm    Post Subject:
Get a s**t stick.
Back to top
 Alert Moderators
Bahco
from United Kingdom
Thanked: 5 times
PostPosted: Sat Dec 23, 2006 1:16 pm    Post Subject:
Paul Barker wrote:
Get a s**t stick.
__________________
Back to top
 Alert Moderators
fitz1
from United Kingdom
Thanked: 10 times
PostPosted: Sat Dec 23, 2006 4:22 pm    Post Subject:
put it through te 500 by 300 wall.
__________________
If your not sure what your doing diy gas work is dangerous and illegal.
Back to top
 Alert Moderators
Display posts from previous:
Post new topic   Reply to topic    DIYnot.com Forum Index > Plumbing and Central Heating All times are GMT
Goto page 1, 2  Next
Page 1 of 2
Jump to:
Who Bends Radiators? 4 360 Sat Dec 08, 2007 12:45 pm
How many bends can you have in a combi boiler flue? 13 440 Sat Nov 03, 2007 11:51 pm
How many bends in foul water pipes? 5 240 Tue Feb 19, 2008 11:33 pm
Number of bends allowed in soil pipe? 11 2080 Sun Mar 09, 2008 5:22 pm
Soil stack - inserting two 135 degree bends 3 180 Mon Aug 31, 2009 6:53 pm
DIYnot
My DIYnot | Advertising | Newsletter
DIYnot.com | How to... | @home | Wiki | Forum
