we have a 2 year old bosch diswasher, originally it stopped draining and was told by a local repair shop that the drain pump had stopped working. we purchased a new drain pump only to find out that this did not cure the problem. we sent the unit into the shop to be checked and they told us that the circuit board has blown a track and it would cost over £100 to replace. we took the unit back and stripped the board out to look, there are 2 components blown, 1 is a 1k resistor marked 102 and the other is a 3 leg transistor with the markings z3m y336, this second part i cannot locate a replacement anywhere so any help appriciated
