heatslave 15/19 problem
23 Dec 2005
previously posted about my boiler pump running all the time, found to be no 3 relay on PCB with burnt out contacts. New board fitted tonight but when dhw is demanded it runs cold until the boiler fires up which could be several minutes. Can I just short out the connectors for the switch to see if divertor v/v moves?
sorry oilman water flow switch on mains inlet, I mean short out connections on pcb that goes to the switch
yep divertor v/v moves and burner kicks in, probably flow switch been knackered for months but not apparent due to other fault
