Worcester Danesmoor 15/19 - Oil Fired ** now with pics **
10 Jul 2006
Clwyd
Hi Folks,
I have just moved to a new house with the above mentioned conventional oil boiler. The problem i have , is that even on full power the tops of some of the radiators arent getting hot. I have bled them ( nowt comes out , water or air) and the boiler appears to be doing what it should.
At my previous house i had a gas combi unit that occasionally did the same thing. Nice easy fix , recharge system with water to 1.5bar on the guage on the front of the machine and away to go!
My question is this , does this boiler need the same thing doing to it , and if so how do i do it ? I cant see an obvious guage anywhere .
Any suggestions appreciated :)
Box
Hi oilman ,
Done that , can obviously see what I am assuming is the pump. What next plz ?
Here are pics of what I can see inside. I have zoomed the pics on the only guage like thing i can see . Hope this helps :confused:
Oh , ok . So where do I recharge the system with water ? Any ideas plz ?
Cheers Kev , the link I posted was from the link you posted , if you get what I mean .
Can I assume you mean the ''How to restore the pressure in a sealed heating systems.'' ?
If so the instructions appear to relate to a combi boiler setup which isnt what I have.
Here are some more pics of what I found in an adjacent cupboard.
I cant feel any cold pipes which I would expect to be a cold feed. Is this then a sealed system ?
This is slowly starting to drive me nuts :rolleyes:
Thanks for the assistance :)
Oh poo , its just dawned on me that there is a tank in the cupboard upstairs. Should I be filling this instead ?
Yes there are two, a large one and a smaller one next to it , approx 1/3 its size
