DIYnot
Local | Network
   DIYnot > Forums
Local | Network
  Forum IndexForum Index     RulesRules    HelpHelp     Join FREERegister Free     BookmarksBookmarks     Watched TopicsWatched Topics     SearchSearch     LoginLogin
wooden Floors
This topic originated from the How to page called Draught proofing a timber floor
Click here to return to the page called Draught proofing a timber floor.
Post new topic   This topic is locked you cannot edit posts or make replies    DIYnot.com Forum Index > Floors, Stairs and Lofts
  View previous topic :: View next topic
Author Message
edwin
from United Kingdom
Thanked: 0 times
PostPosted: Mon Feb 11, 2002 7:49 pm    Post Subject:
wooden Floors
Reply with quote Thanks
I saw an american Tv programme which showed how to draughtproof a pine floor by spreading a sealant with a mop type thing before final sanding. The sealant filled up the gaps between the floorboards most effectively. I have tried to track this product in the UK but with no success. Can you help?
Back to top
 Alert Moderators
If you don't want to see this advert, click here to login or if you are new click here to join free.
Guest
Thanked: 0 times
PostPosted: Tue Sep 24, 2002 9:31 am    Post Subject:
Re: wooden Floors
Could be a two-part floor treatments. There are makes by Sadolin and Clarkes/Clarksons. They are pretty nasty and use an acid, which burns the wood a quite attractive red, unless you use a sealer. The stuff is thick and tough and does a good job of filling in most holes, cracks etc.
This might be what the programme was talking about.
Back to top
 Alert Moderators
Guest
Thanked: 0 times
PostPosted: Tue Oct 22, 2002 2:01 pm    Post Subject:
Re: wooden Floors
I am currently searching the web to find the best method of sealing gaps in wooden floors and found your query. What I have been advised to do is to use the sawdust from the sanding mixed with a PVA type wood glue and use the mixture as a filler.
Back to top
 Alert Moderators
fynn
from United Kingdom
Thanked: 0 times
PostPosted: Mon Jul 28, 2003 10:08 pm    Post Subject:
Re: wooden Floors
did you find out anymore about product below!!?? If so I would be most grateful if you could contact me
Back to top
 Alert Moderators
Giblets46
from United Kingdom
Thanked: 0 times
PostPosted: Mon Jan 12, 2004 4:09 pm    Post Subject:
Under floor insulation
I heard that it is not possible to put insulation under the floor boards as you can get rot, is this all true, would be a lot easier!
Cheers
Edward
Back to top
 Alert Moderators
Bas
from United Kingdom
Thanked: 0 times
PostPosted: Thu Jan 15, 2004 7:18 pm    Post Subject:
one idea I have seen is to use rope or string (dependant on the gap) and stain it - the look is very good
Back to top
 Alert Moderators
masona
from United Kingdom
Thanked: 7 times
PostPosted: Fri Jan 16, 2004 7:33 pm    Post Subject:
Re: Under floor insulation
I don't think so because under the floor should be well ventilated via air brick vent,therefore no bottom heat rise from the bottom oversite to timber for it to condensate.If you think about the loft insulation on the ceiling level is no difference.
Back to top
 Alert Moderators
GwaiLo
from United Kingdom
Thanked: 0 times
PostPosted: Sat Jan 17, 2004 1:45 am    Post Subject:
It is possible, in theory, to insulate a suspended timber gound floor without increasing the risk of rot.
The insulation would need to be supspended between the floor joists and not project lower than them. Easily done if you can get underneath, but less so if you can't.
However, whatever the insulation was suspended on would have to be something that could not rot, so nylon netting might work. However, great care would be needed to ensure that the insulation never dropped or it may block the air flow under the floor.
In practice if you really want a well insulated floor consider replacing the suspended timber floor with a concrete or block and beam floor. Again this needs to be properly designed to avoid bridging the DPC.
__________________
This is not advice. Seek professional advice. I accept no liability errors or omissions.
Back to top
 Alert Moderators
AdamW
from Vatican City State
Thanked: 0 times
PostPosted: Mon Jan 26, 2004 11:52 pm    Post Subject:
This is a technique used for waterproofing clinker-hulled boats so perhaps it might offer some level of flood protection icon_biggrin.gif
Back to top
 Alert Moderators
steveherts
from United Kingdom
Thanked: 0 times
PostPosted: Tue Sep 27, 2005 4:08 pm    Post Subject:
Sealant
I used the brown external frame sealant to fill between my boards. I found it a) easier to apply as I used the gun and b) it is flexible so it doesnt crack like the papier mache filler I used previously
___________________________
Moderator,
Back to top
 Alert Moderators
Display posts from previous:
Post new topic   This topic is locked you cannot edit posts or make replies    DIYnot.com Forum Index > Floors, Stairs and Lofts All times are GMT
Page 1 of 1
Jump to:
Painted wooden floors in a bathroom 10 1020 Wed May 16, 2007 8:33 am
Sound proofing for wooden floors in a Georgiam House? 8 640 Mon Oct 01, 2007 11:52 am
Wooden floors - Durability advice 2 440 Sat May 12, 2007 6:44 am
Preparing wooden floors 2 580 Wed Nov 08, 2006 12:48 pm
Filling cracks in wooden floors with string/rope 2 520 Tue Jan 03, 2006 10:00 pm
DIYnot
My DIYnot | Advertising | Newsletter
DIYnot.com | How to... | @home | Wiki | Forum
