Hoptoint DF62 stopping mid cycle/not draining
23 Dec 2006
Warwickshire
Hi, we have a DF62 which has suddenly started halting when the timer is at about \\\"7 o\\\'clock\\\" the whole machine just goes quiet. If I push the timer past this point it carries on but upon opening the machine it hasn\\\'t rinsed and the bottom is full of cloudy water? Is it terminal? :) Thanks all!
sounds like you have a problem with the drain pump.is the waste pipe clear?
HI
Emptied it out anc cleaned what I could around the impeller. I ran some cleaner through it and, whilst empty, it worked reasonably well. The drain pump is buzzing loudly so I suspect the pump is on its way out.
Cheers!
As per ealrier post I reckon the drain pump is on its way out. Anyone know how I get to it to change it?
Ta very much!!!
