- Joined
- 1 Oct 2006
- Messages
- 148
- Reaction score
- 1
- Country
I am having real problems trying to install a new toilet.
There has been a persistant leak from it, which I presumed was due to me not plumbing in the waste pipes properly. It's one of these toilets with the cistern attached, and sits flush against the wall, so seeing these pipes whilst it was working was impossible. In frustration I bought an extendable flexible pipe, pulled it away from the wall and saw that this wasn't leaking at all, but it was dripping from underneath the bowl.
I raised the toilet onto some blocks, and had a good look and cannot see any cracks in the bowl. I fiddled with the cistern and flushed it a few times, and also let the overflow run constantly (it empties into the toilet bowl). Again I couldn't see any obvious leaks. What I did see however, was a slow drip right at the front of the base- there is nothing from the back. When I investigated this area of the toilet I could feel the bottom was damp- it looks/feels like the whole of that area is slightly damp. Is it possible that the toilet is not waterproof? My best guess at describing it is that it looks like this area of the toilet is porous- maybe due to poor quality manufacturing? Is this anything anyone has experienced, or is there another possibility?
I cannot return the toilet, and it fits perfectly into an awkward area. To buy a new one will cost me a couple of hundred quid- which I am desperate to avoid. I have currently disconnected it completely and am "painting" the bottom of the pan with the BAL sealer that I used to tank the ensuite in the hope of waterproofing it. I haven't tried this yet to see if it solves the problem, as I want to put on a few coats and make sure it dries really well.
Any help/ideas would be gratefully appreciated.
