Merry Christmas and hope someone can advise........
I had some work done in the bathroom and the bathroom radiator was removed without draining the system and then refitted. Now it stays cold/cool. The pipe to the left of the radiator is very hot but the radiator itself and the pipe to the right off of it is cold. This is the pipe with the temp valve on it (but it is not a TRV).
Before the bathroom rad was removed for the work it always got nicely hot!
My system is gravity fed with one rad downstairs and 4 upstairs.
The only thing I have noticed is that the downstairs rad is now boiling (which is good) but it never used to be this hot, just adequately warm. It is though the heat has transferred from the bathroom rad to the downstairs one!
I have tried opening and closing the valves on the bathroom radiator but to no avail.
I opened the bleed valve on the bathroom rad whilst both rad valves were off and no water came out. I then independently opened the bathroom rad valves with the bleed valve open and water came out the bleed valve on both occasions. Hence I am now thinking there is not a blockage?
I am very confused?? I just want some heat from my bathroom radiator.
Any thoughts/assistance would be appreciated.
