Honeywell Room Stat
20 Feb 2006
Hampshire
The stat does not drop back when the room temp drops ie The room gets cold have to turn it manually. There is heater in it I think does that work when heat is demanded. It has three wires one is a neutral it is blue. Do you think it could be missing. It is a new stat. The old one had same prob but was old so I changed it anyway,
It sounds as if your neutral isnt a neutral!
I would put in a digistat such as the drayton, this will sort the problem.
For how long did the old thermostat work before it became faulty?
Just kinda moved so it has never worked for me. Will look at the neutral when it gets warmer.
