Sime Halstaed loosing pressure
29 Dec 2006
Sheffield
Central heating system looses pressure over 36hours. 1.5psi down to 0.5
No leak on rads, any ideas what to check on boiler?
Boiler 13 years old!!!
Pressure relief valve pipe.
Its the one that goes out of the wall behind the boiler. Check this pipe on the outside to see if it is / has been dripping.
Monitor the pressure as you use it. If it goes over 3 bar it will blow out of the PRV. This generally indicates a pressure vessel problem If the PRV leaks while the pressure is below the 3 bar level then the problem is the PRV.
On a 13 year old boiler of any manufacture it is no surprise to find a faulty pressure vessel, PRV or both
Thanks for the help Slugbaby.
It looks like it is the pressure relief valve as it drips and when I tapped the valve it lost all pressure. Another tap and refill and back to a very slow drip.
Any ideas where I can get the part in the UK.
Is it worth changing pressure vessel at same time just to be on the safe side.
It's a Sime Halstead Combi 30/90 originally from Wickes DIY.
