fitting pipe in joists
18 Feb 2006
Birmingham
the last topic got locked due to discussions between plastic and copper
well after reading all the posts i will most likely use plastic pipe with brass compression fittings apart from the piping into the boiler and up to the radiators where it will be copper
anyway if using plastic is it best to notch the top of the joist or drill holes and feed through the middle of the joist?
also how much does the pipe need to be clipped?
Very wise.
Through the middle and thread it.
See the makers info which most is on the web. Clip very well indeed. Clip before and after joints and before and after bends.
Please do read the MIs, and be aware that you can clip too much, because plastic pipe needs room to expand when hot.
In case the point has got missed in the noise, also make sure that you use barrier pipe.
Very wise.
what do u mean by THREAD IT?
will do mate
and yes i know barrier pipe has to be used for the heating side at least
He means 'put it through the hole'.
Another tip - close the end of the pipe when feeding through/under/over stuff, to prevent debris entering the pipe. Coils of Hep2o come with a red cap for this very purpose.
Also, when making on the connection to the end of the coil, always cut back to clean unscratched pipe.
cheers mate
are pipe inserts needed if using brass compression fittings?
DEFINITELY.
I would use tape or a sealant of some sort on the olive as well.
Thread the pipe through the joists.
ChrisR wrote:
DEFINITELY.
All the makers say use only PTFE tape over the olive. Some say use copper olives some brass. Check.
__________________
When threading plastic pipe it is best to insert the stop plug provided and tape all the pipe back about 18 inches to prevent scratches. The scratches can prevent a good seal. Also scratches can give weaks spots where the pipe may split after a number of years.
__________________
MOD 2
use the edit key
