SteveHulme
Joined: 31 Dec 2006 Posts: 1 Location: Oxfordshire, United Kingdom Thanked: 0 times
Posted: Sun Dec 31, 2006 12:48 pm Post Subject: Cooker Extractor Fan - Troubleshooting Tips? |
Hello
I\\\'m trying to work out why the extractor fan above the cooker has stopped working.
The kitchen was fitted by a previous owner, but I\\\'m presuming that the \\\'fuse box\\\' below the extractor unit is the correct one to check and the 3amp fuse in there looks fine (in fact I exchanged it to make sure). I can\\\'t follow the wiring to as it is all tiled in between this fuse box and the extractor unit.
The extractor unit panels look pretty difficult to take off and I haven\\\'t been successful so far.
Is there anything simple I should be checking - inside or outside the house - before I start burrowing into the unit and looking for loose connections?
Many thanks in advance |
Taylortwocities
Joined: 27 Jul 2006 Posts: 4940 Location: Oxfordshire, United Kingdom Thanked: 63 times
Posted: Sun Dec 31, 2006 1:49 pm Post Subject: |
Are you sure that switch is the one for the extract fan? If you assume it makes an ass out of u and me!
I have been to a number of non-op extract fans only to find the isolator is in a cupboard and someone has bushed a box of Shreddies onto the switch and it has turned off.
Well worth the call-out charge that sort of thing!!
If your sure the FCU is the right one, check the supply is leaving the FCU (with a voltage tester or multimeter not a neon screwdriver). If its OK there then test where the cable comes into the extract fan. If you've got power there then there's a fault with the fan.
TTC |
unclebuck001
Joined: 23 Dec 2006 Posts: 51 Location: Kent, United Kingdom Thanked: 0 times
Posted: Sun Dec 31, 2006 5:33 pm Post Subject: |
most extractor fans come with a moulded plug and if a bulb blows it sometimes takes the fuse with it normally the closest one, i would check if there is a plug some where either above your units or in the flu its self, replace that fuse... |
securespark
Joined: 11 Jan 2004 Posts: 16491 Location: Cheshire, United Kingdom Thanked: 14 times
Posted: Sun Dec 31, 2006 10:21 pm Post Subject: |
Simply replacing the fuse may not be enough to ensure you have a working one.
If I had a quid for all those call-outs where customers have insisted that the lamp/fuse is OK because they've checked them, I'd be a millionaire! __________________ As George Michael once said, "..if you're gonna do it, do it right, right?" |
