DIYnot
Local | Network
   DIYnot > Forums
Local | Network
worcester greenstar 28 he plus Fault Code C1
This topic originated from the How to page called Problems associated with noises from the central heating system
Click here to return to the page called Problems associated with noises from the central heating system.
Post new topic   Reply to topic    DIYnot.com Forum Index > Plumbing and Central Heating
Author Message
cdpdesign
from United Kingdom
PostPosted: Mon Jan 01, 2007 11:57 am Reply with quote
Hi there
Had a phone call from my sister who has a worcester greenstar 28 he plus combi running on LPG.
She has had a series of power cuts, as many as 15 in about 3 hours, and when the power finally came on, her boiler was showing fault code C1 which is something to do with the fan (I think!)
Does anyone know what generally leads to this fault code, or if the power cuts could have damaged the boiler? Is there any quick fix for this fault or is it something that will require an engineer? Her partner is an electrician, so if it's something electrical he may be able to fix with the right advice.
Where she lives is rather remote, and she has been quoted over 200 call out plus labour and parts, so at that rate she wouldn't be far off buying a new boiler!!!
Does anybody have an engineers manual for this boiler that I could take a look at?
Any help would be greatly appreciated- you all seem very helpful and knowledgeable...
Thanks in advance!
Back to top
 Alert Moderators
bripl
from United Kingdom
Thanked: 1 time
PostPosted: Mon Jan 01, 2007 12:26 pm Reply with quote
cannot find a 28he plus combi but the c1 code is fan speed too low all you can do is check all the connections and fan, replace as req this is for the r25& 30 he combi
Back to top
 Alert Moderators
ChrisR
from United Kingdom
Thanked: 1134 times
PostPosted: Mon Jan 01, 2007 12:42 pm Reply with quote
FOund it on Partsarena, one GC number off the 35.
This may not work:
http://www.partsarena.net/gas/catalogs/worcester/System/DATA/DS1/89/0@G03@7713231776@2323108T.htm
Turn it off at the mains for ten minutes then on again - works for wobbly vaillants sometimes!
Back to top
 Alert Moderators
cdpdesign
from United Kingdom
PostPosted: Mon Jan 01, 2007 1:10 pm Reply with quote
Tried switching off, will check connections and clean them etc...
the link doesn't work....
Any other ideas?
Does anyone know where she could go to buy a replacement fan from?
Back to top
 Alert Moderators
bripl
from United Kingdom
Thanked: 1 time
PostPosted: Mon Jan 01, 2007 1:19 pm Reply with quote
you would be better to call the manufacturers out as it may need a new board they should have all the bits on the van otherwise you may purchase a fan and find it is the board. this boiler only ran for a few years so maybe worc know something rgi's do not
Back to top
 Alert Moderators
Agile
from United Kingdom
Thanked: 3613 times
PostPosted: Mon Jan 01, 2007 1:38 pm Reply with quote
The C1 fault code is generated by the PCB as an indication but it is not a definitive statement of the faulty component. Its probably more likely to be the PCB has been damaged by voltage spikes.
Unfortunately, apart from Ideal, most manufacturers dont take much trouble protecting boilers from mains bourne interference and potentially harmful voltage spikes.
Having an LPG fuel source makes me expect that she lives in the countryside and is supplied by a rural distribution network with overhead power cables which are prone to lightening strikes and static discharges.
If this is the case it might be well worth while feeding the boiler from a good quality mains filter and surge supressor as sold for computers.
Coincidentally, I had to repair a Potty Paramount boiler in a Synagogue which had been damaged by mains surges which had damaged the fan. The Vaillant in the kitchen had its PCB and supply transformer blown.
Tony Glazier
Back to top
 Alert Moderators
jiminblack
from United Kingdom
Thanked: 190 times
PostPosted: Mon Jan 01, 2007 5:12 pm Reply with quote
Call out Worcester. Most you'll pay is 185.00 for C1 fault which will be the fan or board...most likely the fan though. Been to quite a few where the non return diaphram (bosch call it a bearing plate) has broken away and ingested in to the fan.
Back to top
 Alert Moderators
cdpdesign
from United Kingdom
PostPosted: Mon Jan 01, 2007 9:46 pm Reply with quote
jiminblack, - thanks for your advice; Worcester are attending wednesday- hopefully it won't be too serious.
Back to top
 Alert Moderators
Post new topic   Reply to topic    DIYnot.com Forum Index > Plumbing and Central Heating All times are GMT
Page 1 of 1
Jump to:
New Bosch Worcester Greenstar 37 CDi Boiler EA Fault code 24 40640 Sun Apr 25, 2010 7:03 pm
Code C6 Worcester Greenstar 5 5260 Sun Oct 04, 2009 1:05 pm
Worcester Greenstar 42cdi - Weird Error Code for Heating 3 2620 Tue Dec 22, 2009 11:56 am
Worcester Bosch ZWBR 7-28 HE PLUS - Fault Code C1 11 2880 Mon Aug 20, 2007 7:31 pm
Gloworm Boiler F6 Fault Code 8 1540 Fri Nov 20, 2009 8:04 am
DIYnot
Please read our Privacy Policy. Copyright © 2000-2015 DIYnot Limited.
