DIYnot
Local | Network
   DIYnot > Forums
Local | Network
Mira Advance shower service light!
Author Message
Templer
from United Kingdom
PostPosted: Tue Jan 02, 2007 2:45 pm Reply with quote
this is my first post here and probably my last attempt at finding a solution to my shower problem, before i buy a new one icon_rolleyes.gif
Shower: Mira
Model: Advance 8.7s
Rated: 8.7kw
Supply 240v
Age: 4 years
Problem: Recently the shower service light appears on, then the shower
water turns cold, we then wait a few moments after turning the shower off at the main pull cord, everything appears to work fine then.
I have a limescale remover attached to the cold water feed inlet, and also cleaned the water inlet filter contained with in the shower unit, but the problem still persists.
This has now become a regular routine, every time we want to use this appliance, now the shower refuses to work. When we press the on button, a weird low buzzing noise is heard but no flow from the shower,
a friend who had an identical shower,had the same problem, he replaced the PCB at a cost of 90.00, as advised by an electrician, but the shower still did not work.icon_eek.gif
I expect having paid 300.00 for a shower to last longer then this, if anyone has a solution to this problem or can steer me in the right direction, i would be very great full.
Many thanks for your attention.
Back to top
 Alert Moderators
jj4091
from United Kingdom
Thanked: 216 times
PostPosted: Tue Jan 02, 2007 3:38 pm Reply with quote
Do a Google search for mira showers, there is a web site that will answer your question but I cannot remember the address.
Back to top
 Alert Moderators
Steve
from United Kingdom
Thanked: 226 times
PostPosted: Tue Jan 02, 2007 4:23 pm Reply with quote
300?! Get down B&Q and buy a new one for <100.
Honestly, buying a new one is often cheaper than fixing it.
4 years is a little short for a shower's life. Not sure about the Mira brand though.
Back to top
 Alert Moderators
kevnurse
from United Kingdom
Thanked: 4 times
PostPosted: Tue Jan 02, 2007 4:34 pm Reply with quote
You should normally hear a clunk when the shower is switched on. The clunk is the solenoid valve opening properly to allow the water in. No clunk but a buzzing noise instead means that the solenoid coil is powered, but the valve stem is jammed. You can replace the valve (incl coil) but you need to know what you're doing.
Back to top
 Alert Moderators
Templer
from United Kingdom
PostPosted: Wed Jan 03, 2007 12:58 am Reply with quote
To those who mean well, thank you for you replies.
Have decided that this issue of the faulty shower cannot wait
any longer e.g wife-nag nag nag, have opted for the easier
route and taken crafty1289 advice,
but a big thanks to kevnurse's constructive appraisal,
sounds to me you could be right, but alas time is not on my side.
Thanks again everyone.
Back to top
 Alert Moderators
securespark
from United Kingdom
Thanked: 475 times
PostPosted: Wed Jan 03, 2007 7:14 am Reply with quote
Back to top
 Alert Moderators
Page 1 of 1
Jump to:
MIRA ELECTRICAL SHOWER- ATL ADVANCE THERMOSTATIC 10 200 Wed Dec 18, 2013 9:23 pm
Mira Advance Thermostatic Flow Problem 3 180 Tue Nov 01, 2011 8:51 am
miran advance thermostatic shower 9 220 Thu May 08, 2014 11:35 am
Spark wants money in advance 34 2900 Mon Dec 31, 2007 11:20 am
mira sport shower 8.5kw, low pressure light 13 180 Sun Sep 04, 2011 2:12 pm
DIYnot
Please read our Privacy Policy. Copyright © 2000-2015 DIYnot Limited.
