Joined: 03 Jan 2007 Posts: 15 Location: Kent, United Kingdom Thanked: 0 times
Posted: Wed Jan 03, 2007 5:06 pm Post Subject:
Stair Fixings
I have bought a pre assembled staircase and am fitting it into a well that is open on one side. The bottom is to a concrete floor and the upper floor is wooden. What fixings and method of fixing should I use?
Posted: Fri Jan 05, 2007 4:16 pm Post Subject:
Yes eventually. Something simple but if possible I would like to add it later due to financial constraints. I also have a floor to lay first but that I can manage.
I will ideally have a banister and full railings round the top landing sweeping down one side of the stairs.
Joined: 05 Jan 2003 Posts: 10852 Location: Essex, United Kingdom Thanked: 7 times
Posted: Fri Jan 05, 2007 4:42 pm Post Subject:
Ahhh, this is where it get complicated!
The newel post need to be cut out ready onto the trimmer on the first floor level and the string cut out with mortise & tennon and the same on the bottom floor level.
I used to make staircases and it's not easy to do the cutting of the newel post etc.
Unless you're thinking of using www.richardburbidge.co.uk handrail kit but even then you would need already fitted newel post although it's not impossible to do afterward, I'm surprised the string has no mortise and tennon ready for the newel post which is normally for wall on both side.
I don't know what your capabilities are for carpentry level
What area in Kent are you from?
__________________ Always judge a man by the way he treats someone who is of no use to him
Joined: 02 Feb 2006 Posts: 11053 Location: Staffordshire, United Kingdom Thanked: 71 times
Posted: Fri Jan 05, 2007 5:38 pm Post Subject:
agree with masona thus far.
the side string fixings coupled with the top trimmer fixings will be sufficient.
if you're still not happy fix a concealed angle bracket at the bottom of the stairs, on the inside of the stringer. this will have to be drilled to the concrete floor first and the stairs lowered along side it.
as masona says, you will have to mortice and tenon a newel at the top prior to installation.
i strongly recommend you fix a temporary hand rail until you come up with the dollars for a new one.
Posted: Sat Jan 06, 2007 7:14 pm Post Subject:
Thanks Chaps. Unfortunately due to time constraints (the Wife) I have had to go ahead and install the stairs without newell posts and they went fine. I know this will cause problems when fitting bannisters but hey ho.
I used the idea of the brackets non wall side top and bottom and it worked a treat. Once again thanks for all your help, I may post a piccie of it done soon.
Posted: Mon Jan 08, 2007 10:21 am Post Subject:
Well They are in. Not sure they are to your standards Masona or yours Noseall but I am happy with them and they are solid. Here's a piccie and thanks for all your help.
Posted: Mon Jan 08, 2007 2:00 pm Post Subject:
looks good.
don't forget that temporary handrail though. it's when you're drunk in the middle of the night, or if the wifes carrying a baby down the stairs, that things can get a little sticky.
You cannot post new topics in this forum You cannot reply to topics in this forum You cannot edit your posts in this forum You cannot delete your posts in this forum You cannot vote in polls in this forum
