- Joined
- 7 Jun 2004
- Messages
- 33
- Reaction score
- 0
- Country
Hello wonderful helpful plumbers . I have a indirect sysytem with 3 pipes from the boiler, 1 hot feed to radiators and tank and 2 returns, the pump is on the radiator return. During the summer it gradually stopped heating the hot water via gravity and water would only flow around if the heating was on (pump forcing it through the coil I quess) This was fine as I was lazy and just used the immersion heater and thought all would be ok as winter is approaching and heating will be on and water will get hot. Well this worked for a bit but now I get continous air locks in the heating causing hot water to be pumped out. The return to the pump from rads is the one that fills with air as the water trickles over like a waterfall, causing the bioler to whoosh as the water enters it. When I get the air out it will run for 2 hrs heating all rads then she just pumps out with a lot of whooshing etc.
(could be when the thermostat closes the 2 port valve closes when the hot water is to temp ?) Originally I believed I had a primatic system as could only find one tank utill I drained it today when I found a little one hidden by lagging .
I think I may have a blockage somewhere as the I quess the gravity hot water problem is maybe related to the pumping out.
Any suggestions of a fault finding process or where to look first ?
Thanks in advance
Thanks in advance
