DIYnot
Local | Network
   DIYnot > Forums
Local | Network
Replacing Radiator Valve
This topic originated from the How to page called Fixing a leaking radiator
Click here to return to the page called Fixing a leaking radiator.
Post new topic   Reply to topic    DIYnot.com Forum Index > Plumbing and Central Heating
Author Message
KGann
from United Kingdom
PostPosted: Thu Jan 04, 2007 9:20 pm Reply with quote
I need to replace a valve on my upstairs bathroom radiator as the 'head' is cracked and the rad cannot be turned on brrrrr.
There is a combi boiler system in the house. There is not a 'drain off' on the pipework for the heating. I assume that in order to drain down the system to replace the valve I need to:
a. Turn off the water coming into the combi from the mains. The combi has a filling loop.
b. 'Open' the pipework (by cutting) at a low point (ground floor) to allow the water to drain off - whilst about it may as well fit a new drain off?
c. Bleed the radiators to allow complete drain off.
d. Replace valve!
e. When turning the water back on the heating pipework is filled again from the filling loop?
f. Turn water and boiler back on.
g. Re-bleed radiators (does it matter in what order these are done?).
I think this will work, though confirmation would be great. My thought is that this is a lot of work to replace one valve. So firstly, is there an easier way of doing this? And, have I got it right if I go ahead with the method above?
Back to top
 Alert Moderators
JohnD
from United Kingdom
Thanked: 1087 times
PostPosted: Thu Jan 04, 2007 9:29 pm Reply with quote
If it is just the plastic head that is cracked you can probably just change that. It will probably just pull off to reveal a flat end to the spindle. Some have a fixing screw and a square end.
If you take an undamaged cap off another valve with you to the plumbers merchant you can see if it will fit a new tap. You will probably have to buy a complete tap but they are only a couple of pounds.
If you have to fit a complete valve buy a thermostatic one which is dearer but more energy efficient.
You will not have to drain the system to fit a new valve. As it is sealed, water can only come out if air gets in. Shut off the rad at the both ends. When you slacken the joint water will gurgle out odf the rad but you can catch it with a basin and old towel. To make it come out faster loosen the bleed valve at the top. When you remove the old valve a little water will trickle out, then it will stop. Do not open the valve at the other end. Observe the water that comes out to see if it black or contains sediment or sludge.
Back to top
 Alert Moderators
holty
from United Kingdom
Thanked: 502 times
PostPosted: Thu Jan 04, 2007 9:36 pm Reply with quote
if its the spindle that broke, then try turning all rad valves off to each rad to save as much draining down as possible, also not recomended, but you could then use the prv in the combi to drain the upstairs thats if the boilers downstairs .
Back to top
 Alert Moderators
Post new topic   Reply to topic    DIYnot.com Forum Index > Plumbing and Central Heating All times are GMT
Page 1 of 1
Jump to:
Replacing a radiator valve 4 1020 Thu Oct 05, 2006 10:14 am
Replacing a radiator - radiator valve tails 3 960 Thu Dec 06, 2007 10:49 am
Replacing a faulty radiator valve - didn't quite work :-( 11 200 Mon Apr 08, 2013 5:20 pm
replacing radiator valve with TRV 5 9140 Wed Oct 06, 2004 9:12 pm
Replacing a leaking Radiator Thermostatic Valve 2 1440 Tue Oct 03, 2006 1:10 pm
DIYnot
