DIYnot
Local | Network
   DIYnot > Forums
Local | Network
  Forum IndexForum Index     RulesRules    HelpHelp     Join FREERegister Free     BookmarksBookmarks     Watched TopicsWatched Topics     SearchSearch     LoginLogin
Switch does nothing! safe to remove??
This topic originated from the How to page called Replacing a one way light switch
Click here to return to the page called Replacing a one way light switch.
  View previous topic :: View next topic
Author Message
BenLovesDIY
from United Kingdom
Thanked: 0 times
PostPosted: Fri Jan 05, 2007 12:18 pm    Post Subject:
Reply with quote Thanks
I have a single switch which appears to do nothing! all my lights work through other switches....I just seem to have a spare on the wall!!
Would you recommend removing and filling the hole, or actually putting some time into finding what it originally did?!
Cheers
Back to top
 Alert Moderators
If you don't want to see this advert, click here to login or if you are new click here to join free.
sm1thson
from United Kingdom
Thanked: 0 times
PostPosted: Fri Jan 05, 2007 12:28 pm    Post Subject:
well you cant fill it untill you know the cable to it are dead. there are rules about live cables only running vertically and horizontaly from acessories and in the corners and top edge of the wall -this is so you dont hit a live cable putting a picture hook etc in the wall, if you fill it there will be nothing to say the cables are there.
so its up to you:
1) leave it as it is.
2) put some time in to ensure its dead, then fill it.
Back to top
 Alert Moderators
BenLovesDIY
from United Kingdom
Thanked: 0 times
PostPosted: Fri Jan 05, 2007 1:27 pm    Post Subject:
the confusing thing is that it was in the downstairs bathroom which i thought had to have a pull chord?
Think i'll just remove it!
Might need to start a manual on where potential hazards in the house might be!!
Ben
Back to top
 Alert Moderators
JohnD
from United Kingdom
Thanked: 54 times
PostPosted: Fri Jan 05, 2007 1:35 pm    Post Subject:
He's right.
Why did you ask?
Back to top
 Alert Moderators
EddieCurrent
from United Kingdom
Thanked: 0 times
PostPosted: Fri Jan 05, 2007 1:47 pm    Post Subject:
I know it's a long shot, but it is not a fan isolator switch by any chance ??
Back to top
 Alert Moderators
Yarn
from United Kingdom
Thanked: 0 times
PostPosted: Fri Jan 05, 2007 2:04 pm    Post Subject:
Is the mystery switch at a position and height on the wall similar to your other light switches?
Are you sure the control is a light switch and not a FCU?
A switch has to have a live cable in and another cable that is being switched. Have you actually taken the facia of this switch and confirmed that it has any wires going to it. (If there are no wires inside, then i would say that it is safe to fill!!)
Back to top
 Alert Moderators
BenLovesDIY
from United Kingdom
Thanked: 0 times
PostPosted: Fri Jan 05, 2007 2:14 pm    Post Subject:
Yeah, i've taken off the cover and there are wires going to it.
It is normal height for a light switch (but also there is a pull chord in the same room)
There is only 1 light in the room, no fan, one pull chord that works the light and then the 'other switch'!!
Back to top
 Alert Moderators
securespark
from United Kingdom
Thanked: 14 times
PostPosted: Fri Jan 05, 2007 2:40 pm    Post Subject:
Is it live, then?
__________________
As George Michael once said, "..if you're gonna do it, do it right, right?"
Back to top
 Alert Moderators
Yarn
from United Kingdom
Thanked: 0 times
PostPosted: Fri Jan 05, 2007 2:42 pm    Post Subject:
how many different cables enter the box behind the switch ?
Back to top
 Alert Moderators
Display posts from previous:
Page 1 of 1
Jump to:
how safe to remove an earth wire? 6 920 Fri Oct 03, 2008 4:16 pm
Best way to remove redundant light switch? 2 300 Fri Oct 31, 2008 4:16 am
How do I remove a ceiling pull switch? 2 400 Sun May 28, 2006 11:05 am
Remove Socket 3 640 Tue Feb 05, 2008 9:31 am
remove cover of plug 6 2400 Fri Jul 28, 2006 11:51 am
DIYnot
My DIYnot | Advertising | Newsletter
DIYnot.com | How to... | @home | Wiki | Forum
