Washing machine
SC
5 Jan 2007
London
My washing machine is filling up with water even when switched off. Initially I had a leak which was across the kitchen floor - the hose being loose. Now I can not get rid of the machine filling up. Having to drain it everyday. Please HELP!!
water inlet solenoid valve inside the machine is letting by
try turning the water off at the other end of the hose where there (should) be a valve for now :idea:
What is the cost of doing this?
Thanks kevplumb,
Can this problem be repaired and if so how complicated is it?
_________________________________
Lynda, moderator
please note forum rules, item g and rule 9
