Hot water is causing central heating to switch off...?
4 Jan 2007
Any thoughts would be much appreciated...
Basically hot water is fine but when it appears to have filled the tank the central heating switches off- the pilot light is still there but it is not firing up.Checked all thermostats etc.
If we use up the water then we can start it up again for another hour or so?
Thanks - any ideas of a rough cost of replacement?
Is is a quick job or do they need to drain the system etc? How many hours of work and the cost of the part?
yes drain down req but only to below the valve, I used to air lock the system to do it using a bung kit.should take 1-1/2 hours if straight forward.
alternatively just leave a hot tap running all the time :evil:
sorry it may just require the head , which wont require a drain down
I have had a quote for around 3 hours labour +parts=£300
cash price- I am in the south
If you have a 3 port valve, the problem will most likely be either the small motor within the actuator head or a micro switch within the head.
A motor is around £15 and a complete head around £45 which usually can be changed easily. If you can remove the head you should be able to see how it reacts to the various selections. Sounds as though it is not moving across to the CH only position or if it is then the micro switch is preventing the boiler from lighting.
suggest you read more on 3 port mid position valves.
:rolleyes: :rolleyes: :rolleyes:
