DIYnot
Local | Network
   DIYnot > Forums
Local | Network
  Forum IndexForum Index     RulesRules    HelpHelp     Join FREERegister Free     BookmarksBookmarks     Watched TopicsWatched Topics     SearchSearch     LoginLogin
Distance from drainage/water supply
This topic originated from the How to page called Installing a washing machine
Click here to return to the page called Installing a washing machine.
Post new topic   Reply to topic    DIYnot.com Forum Index > Appliances
  View previous topic :: View next topic
Author Message
annabanana
from United Kingdom
Thanked: 0 times
PostPosted: Sat Jan 06, 2007 10:02 am    Post Subject:
Reply with quote Thanks
Hi.
I hope someone might be able to help. We'd like to install a dishwasher in the kitchen of the house we've just moved into. There's no room for the washing machine and dishwasher near the sink, but one of them could be moved to the other side of the kitchen with pipes running under/behind the units. Would this work? How far from the drainage and water supply can the appliance be? Does it matter?
Any thoughts would be gratefully received.
Thanks,
Anna
Back to top
 Alert Moderators
If you don't want to see this advert, click here to login or if you are new click here to join free.
jj4091
from United Kingdom
Thanked: 8 times
PostPosted: Sat Jan 06, 2007 1:59 pm    Post Subject:
It does not matter from the water supply side, but you would need to be able to get sufficient fall on the drain pipe. You will also need a convenient socket.
Back to top
 Alert Moderators
annabanana
from United Kingdom
Thanked: 0 times
PostPosted: Sun Jan 07, 2007 3:19 pm    Post Subject:
Thanks that's really useful. The socket bit is fine too. Can I just check - what does sufficient fall mean exactly? A continuous slope to the end or something else?
Thanks again.
Anna
Back to top
 Alert Moderators
trotters
from United Kingdom
Thanked: 0 times
PostPosted: Sun Jan 07, 2007 7:18 pm    Post Subject:
The best way is to extend the drainage pipe TO the appliance rather than trying to extend the drain hose FROM the appliance.
Using this method, the drain pump of the appliance won't be over worked, also if you are extending the supply pipework it is a good idea to make sure you can access the taps without having to drag the appliance out (In case of a leak etc).
Back to top
 Alert Moderators
Ash-GT
from United Kingdom
Thanked: 0 times
PostPosted: Wed Jan 24, 2007 12:00 am    Post Subject:
Firstly, great site. This is my first post, so be gentle!
I have exactly the same problem, and thought of piping to the new applicance, however, space under the kitchen units is limited, and it is only possible for me to get a 1cm fall over 1m (total distance is about 4 meters).
However, after looking at a friends kitchen install (who had a similar type of problem - from MFI), they simply used an washing machine extension hose and a 5m water pipe to solve the issue.
His kitchen has been in for about 2 years, and they have never had a problem.
I am now thinking to go down the MFI route, and simple use extension pipes?
Back to top
 Alert Moderators
EVER-PURE
from United Kingdom
Thanked: 0 times
PostPosted: Wed Jan 24, 2007 9:27 am    Post Subject:
For the drainage the size of the pipe and trap has to be 40mm, the maximum distance is 3 metres from the stack and the gradient is 18- 45mm per metre
Back to top
 Alert Moderators
Ash-GT
from United Kingdom
Thanked: 0 times
PostPosted: Wed Jan 24, 2007 8:15 pm    Post Subject:
Re: Distance from drainage/water supply
That would explain it. No chance of getting that gradient under your average kitchen unit!
Back to top
 Alert Moderators
MickUK
from United Kingdom
Thanked: 0 times
PostPosted: Sat Jan 05, 2008 5:10 pm    Post Subject:
Hi all, first post & a cracking site! Sorry to drag up an old thread but i'm having the same probs. Had to move the dishwasher due to buying a bigger cooker. When it's said extend the drainage pipe rather than the hose, are we talking about the 40mm plastic piping?
Cheers all!
Mick
Back to top
 Alert Moderators
Display posts from previous:
Post new topic   Reply to topic    DIYnot.com Forum Index > Appliances All times are GMT
Page 1 of 1
Jump to:
cooker hood extraction distance. 3 400 Thu Apr 30, 2009 12:33 pm
min distance between cooker hob and cooker hood 2 300 Mon Aug 25, 2008 8:39 am
Cooker hood extraction distance 5 720 Sat Mar 19, 2005 10:36 am
Distance between oven and Kitchen base unit 2 400 Sun Apr 27, 2008 8:21 pm
safe distance of gas cookers to kitchen cupboards 2 460 Sat Nov 25, 2006 11:47 am
DIYnot
My DIYnot | Advertising | Newsletter
DIYnot.com | How to... | @home | Wiki | Forum
