Removing circ saw blade. Stuck! Help!
23 Feb 2005
Surrey
I have a Wickes circular saw, the one that currently costs £79.99 instore. Actually made by Kress but a decent and powerful saw, only cost me a fiver on eBay :wink:
Anyway the blade needs changing and I can't get the nut undone. It takes an allen key, and I've tried wd40 and whacking it with a hammer :shock: like you do on drill chucks but it just won't shift.
Any ideas? If I take the whole machine apart will that help in any way?
May be a left hand thread though most circ saws are right hand thread if th eblade is to the right of the saw when viewed from the back.
Jason
You have locked the blade, so its just that the bolt is very tight?
A longer allen key, or an allen key with a ring spanner slipped over the end for more legerage.
Have you locked the blade ? I'm not familiar with this particular saw, but sometimes it's necessary to jam a piece of wood between one tooth & the sole plate & then try all the methods above. Good Luck. Malkie
Conclusion.
Was a right hand thread, I actually ended up completely wiping out the allen key socket trying to remove it. Had to use grinder to cut a slot in the top of the bolt, and use a piece of angle iron as a lever to get it loose. So if anyone else has a Wickes/Kress 6066, it's a RIGHT HANDED THREAD! I should be able to reuse the screw but it's only a standard M8 anyways. Thanks for alll replies.
Deluks said:
Conclusion.
even if it wasn't a standard thread i wouldn't recomend re-using the bolt as you dont know how much dammage has been done !!!!!
hammerd heated cooled weakend :roll:
