DIYnot
Local | Network
   DIYnot > Forums
Local | Network
  Forum IndexForum Index     RulesRules    HelpHelp     Join FREERegister Free     BookmarksBookmarks     Watched TopicsWatched Topics     SearchSearch     LoginLogin
removing anaglypta wallpaper
This topic originated from the How to page called Removing thick textured paper
Click here to return to the page called Removing thick textured paper.
Goto page 1, 2  Next
Post new topic   Reply to topic    DIYnot.com Forum Index > Decorating and Painting
  View previous topic :: View next topic
Author Message
Tracybrooks
from United Kingdom
Thanked: 0 times
PostPosted: Mon Mar 08, 2004 11:02 am    Post Subject:
Reply with quote Thanks
How do you remove this stuff when its paperon onto dry-lined walls. Its pulls some of the paint off in its analglypta pattern and leaves a real mess. I am considering just using a heavy grade lining paper to go over the top but am worried that this pattern may still show through. any one with any top tips.
Back to top
 Alert Moderators
If you don't want to see this advert, click here to login or if you are new click here to join free.
billybob
from United Kingdom
Thanked: 0 times
PostPosted: Tue Mar 09, 2004 6:58 pm    Post Subject:
unfortunatley this can be a nightmare on dry lined walls, can you tell me if it has been emulsioned before ?
Back to top
 Alert Moderators
Tracybrooks
from United Kingdom
Thanked: 0 times
PostPosted: Thu Apr 01, 2004 8:02 am    Post Subject:
yes the wall paper has been emulsioned billybob, probably a couple of times!. I've been away do apologies for my slow reply!.
Back to top
 Alert Moderators
PaulB
from United Kingdom
Thanked: 0 times
PostPosted: Fri Feb 04, 2005 2:49 pm    Post Subject:
Asbestos
The law requires textured paint/plasters/finishes only to be removed by a licensed contractor when these coatings contain asbestos. Asbestos was in these finishes until the end of the 1980s. Tackling a job yourself (without getting a test to see whether it contains asbestos - labs in "yellow pages") will leave you risking you/your family's health and also leave residual contamination in your home. Seek advice from you local council.
Back to top
 Alert Moderators
2scoops0406
from United Kingdom
Thanked: 1 time
PostPosted: Fri Feb 04, 2005 2:53 pm    Post Subject:
To whom it may concern, permission to go for a p*ss without a certificate of competance (or is that continence?)
Back to top
 Alert Moderators
PaulB
from United Kingdom
Thanked: 0 times
PostPosted: Fri Feb 04, 2005 2:57 pm    Post Subject:
More asbestos
If you have already taken the texture off, a simple test can establish whether it contained asbestos and contaminated your home. Again "yellow pages". Cleaning the mess with a domestic vacuum cleaner would have spread the contamination throughout your home and still be doing it! Get the situation checked - and if it is bad news, you will also want to talk to your doctor. Sorry to be a bringer of bad news.
Back to top
 Alert Moderators
2scoops0406
from United Kingdom
Thanked: 1 time
PostPosted: Fri Feb 04, 2005 2:59 pm    Post Subject:
Anaglypta is simply blown wallpaper isn't it ?? What's with the asbestos thing?
Back to top
 Alert Moderators
Thermo
from United Kingdom
Thanked: 31 times
PostPosted: Fri Feb 04, 2005 6:00 pm    Post Subject:
dont know quite what hes up to, but seems to be talking out of the lower rear hole.
__________________
have grace to accept what cant be changed, strength to change what can, wisdom to see the difference
Back to top
 Alert Moderators
masona
from United Kingdom
Thanked: 7 times
PostPosted: Fri Feb 04, 2005 6:04 pm    Post Subject:
__________________
Always judge a man by the way he treats someone who is of no use to him
Back to top
 Alert Moderators
Thermo
from United Kingdom
Thanked: 31 times
PostPosted: Fri Feb 04, 2005 6:13 pm    Post Subject:
no the asbestos man
__________________
Back to top
 Alert Moderators
david and julie
from United Kingdom
Thanked: 0 times
PostPosted: Fri Feb 04, 2005 11:57 pm    Post Subject:
Well I reckon PaulB is getting confused with old Artex.
Back to top
 Alert Moderators
confidentincompetent
from United Kingdom
Thanked: 0 times
PostPosted: Wed Feb 09, 2005 12:05 am    Post Subject:
Re: More asbestos
[quote="PaulB"]If you have already taken the texture off, a simple test can establish whether it contained asbestos and contaminated your home.
but dont worry it takes forty yrs to kill ya
Paul b is a computer generated response from the pinstripes at the enviroment agency.
Try a steam stripper, or score surface, soak well with warm water, have a fag, soak again, peel at areas where face of paper is loosening soak again, be patient and it should scrape off easy once face has lifted, tho soak each section again just b4 you start scraping on plasterboard.
__________________
new labour? rob the poor to pay the rich.?
Back to top
 Alert Moderators
kevplumb
from United States of America
Thanked: 400 times
PostPosted: Wed Feb 09, 2005 9:50 am    Post Subject:
Re: More asbestos
[quote="confidentincompetent"]
__________________
a little thanks
goes a long way
Back to top
 Alert Moderators
from United Kingdom
Thanked: 0 times
PostPosted: Wed Feb 09, 2005 11:22 pm    Post Subject:
Re: More asbestos
never heard of anaglypta having assie in icon_rolleyes.gif[/quote]
I know wot a plonker, He probly owns an asbestos removal company.
Seriously tho with 'asbestos artex' the best way is to skim over it and leave it alone innit. icon_twisted.gif
__________________
Back to top
 Alert Moderators
batman1
from United Kingdom
Thanked: 0 times
PostPosted: Thu Apr 24, 2008 6:39 pm    Post Subject:
how can you tell if there is asbestos in the walls?
Back to top
 Alert Moderators
Display posts from previous:
Post new topic   Reply to topic    DIYnot.com Forum Index > Decorating and Painting All times are GMT
Goto page 1, 2  Next
Page 1 of 2
Jump to:
Anaglypta - Cover it up without removing it? 7 580 Thu Aug 28, 2008 5:50 pm
Anaglypta Wallpaper Removal - Tips? - WallWik? 2 840 Sun Nov 19, 2006 4:27 pm
Unpatterned anaglypta? 9 660 Fri Jun 08, 2007 12:16 pm
Repairing peeling painted anaglypta above rad 2 320 Sat Mar 11, 2006 5:26 pm
Removing Wallpaper? 3 240 Wed May 21, 2008 6:44 pm
DIYnot
My DIYnot | Advertising | Newsletter
DIYnot.com | How to... | @home | Wiki | Forum
