DIYnot
Local | Network
   DIYnot > Forums
Local | Network
Draughty UPVC Front Door
Post new topic   Reply to topic    DIYnot.com Forum Index > Windows and Doors
Author Message
Iotrez
from United Kingdom
PostPosted: Mon Jan 08, 2007 10:26 pm Reply with quote
Hi all,
I am renovating a 1950's ex-local authority house that had new double glazed windows and doors fitted 3 yrs ago. Unfortunately, it's looks like a bunch of cowboys ripped off the poor old chap that lived here because its absolutely dreadful. However, it was passed by a building inspector shortly after it was fitted!
The windows are very draughty and not to be leant on as they are not 100% securely fixed. The main problem though is the front door which howells when it is windy and whistles the rest of the time. I have replaced the rubber draught excluder but it doesn't seem to have made any difference.
Does anyone have any ideas?
Back to top
 Alert Moderators
JohnD
from United Kingdom
Thanked: 1459 times
PostPosted: Mon Jan 08, 2007 10:39 pm Reply with quote
Is there a gap between the frame and the brickwork? If so, that can be fixed using expanding foam in a sort of aerosol can. Come back because there are ways to do it neatly and without damaging the plastic parts. I have used it round my wooden frames, it seals draughts and also holds it firmly in place.
If the gap is between the opening part of the window, or the door and the frame, that needs a different approach.
Back to top
 Alert Moderators
derv1980
from United Kingdom
Thanked: 1 time
PostPosted: Tue Jan 09, 2007 10:05 am Reply with quote
is it very easy to pull the handle up as in locking the door? if so you can adjust the cams, if it has any to pull the door in tighter. they are on the locking edge of the door bout quarter way from top and bottom. usually 4mm allen key. turn them 180 degrees see if that helps.
Back to top
 Alert Moderators
simon949
from United Kingdom
PostPosted: Tue Jan 09, 2007 5:10 pm Reply with quote
I have a UPVC door with exactly this problem, what is the different approach?
Many Thanks
Back to top
 Alert Moderators
JohnD
from United Kingdom
Thanked: 1459 times
PostPosted: Tue Jan 09, 2007 5:20 pm Reply with quote
I'm not a plastic door man, but someone will be along soon, I'm sure icon_wink.gif
Back to top
 Alert Moderators
Post new topic   Reply to topic    DIYnot.com Forum Index > Windows and Doors All times are GMT
Page 1 of 1
Jump to:
Draughty front upvc door 4 120 Wed Jan 29, 2014 7:22 pm
New UPVC windows draughty 9 5720 Tue Nov 16, 2010 2:55 pm
Draughty Upvc Window internal trim 8 520 Sat Oct 08, 2011 8:01 pm
Draughty UPVC windows - how do I fix this 7 9680 Fri Sep 11, 2009 5:37 pm
uPVC window catch won't shut, getting draughty! 3 200 Sun Feb 10, 2013 12:17 pm
DIYnot
Please read our Privacy Policy. Copyright © 2000-2015 DIYnot Limited.
