I had a new central heating system installed about 10 months ago and it has been nothing but trouble. We had the combi ripped out and a condensing boiler, hot water tank system put in.
The main problem now is that every month or so the system becomes very noisy. So much so that when the hot water kicks in in the morning the knocks, creaks and air noises are so loud they wake us up. I have tried topping up the pressure in the past and this may have had an effect (but I cannot be sure) but this time the pressure has not dropped at all and still the noises have started again.
When the noises start you also start getting alot of noise from the heating/radiator system. You can hear the water circulating and lots of knocks and gurgles coming from the raditors when the hot water is running even though the heating is not on.
So my questions are these....
1) any ideas on how to stop the periodic noisy hot water?
2) why does the system circulate the water in the raditors even when the heating function is switched off - should it be doing this?
Any advice appreciated.
