No Central Heating Or Hot Water!
9 Jan 2007
Liverpool
Could anyone please cast their professional opinion over a current problem I am experiencing with my installer & system??
I had a complete system installed just under 2 years ago consisting of a Baxi Instant Combi 80HE boiler & 7 radiators. The boiler has not worked properly since installation and I have had the installer out so many times I am unsure of what to do next. At first it was to correct shoddy workmanship but then the boiler became faulty.They are a supposed reputable company and are corgi registered.I have had to take their own monthly boiler servicing insurance out so that I can try & have them sort the problem!Everytime they call out they fiddle with the boiler & it works for a couple of days, sometimes weeks then back to square one again. At first they claimed there maybe a loose wire in the power switch & yes the wire was hanging out however this did not solve the problem.They then said it maybe the PCB & I had 3 other engineers from different companies say the same. They tried 3 or 4 PCBs but to no avail. Then they said they would change an electrically operated valve to a mechanical one and still no joy.The boiler was firing up but then all we would here was a repeated click/clunking of what I assume was it attempting to fire up and we would have to turn it off.If the preheat was turned off sometimes it would work and others not. Now when we switch it on the red light flashes below the 50C and the green above the tap symbol and nothing happens.Apologies for the essay, just thought I would try to provide as much detail of the problem as possible.
Thankyou in advance should you see a resolution to my problem!
