DIYnot
Local | Network
   DIYnot > Forums
Local | Network
  Forum IndexForum Index     RulesRules    HelpHelp     Join FREERegister Free     BookmarksBookmarks     Watched TopicsWatched Topics     SearchSearch     LoginLogin
Finishing round a curve
This topic originated from the How to page called Wooden flooring
Click here to return to the page called Wooden flooring.
Post new topic   Reply to topic    DIYnot.com Forum Index > Floors, Stairs and Lofts
  View previous topic :: View next topic
Author Message
soggybiscuit
from United Kingdom
Thanked: 0 times
PostPosted: Wed Jan 10, 2007 11:26 am    Post Subject:
Reply with quote Thanks
I have fitted a solid oak floor in my hallway and am putting scotia all the way round but there is a tight curve in the hallway opposite the bullnose how do I finish this area off to hide the expansion gap.
Back to top
 Alert Moderators
If you don't want to see this advert, click here to login or if you are new click here to join free.
WabbitPoo
from United Kingdom
Thanked: 3 times
PostPosted: Mon Jan 15, 2007 10:38 am    Post Subject:
Sorry, I dont have an answer, and I don't wish to hijack your thread, but I have a similar query over trim for laminate flooring in the bathroom - we have a curved shower tray, but any trim I have seen won't bend to that radius. Anyone know answers to this and to OP's question?
Back to top
 Alert Moderators
WFRN
from United Kingdom
Thanked: 0 times
PostPosted: Thu Jan 18, 2007 12:33 am    Post Subject:
Curves
Kahrs have a flexi-edge that is made to go around tight curves that might help.
If you already have the wood scotia you can cut a number of grooves (saw blade width) in the back (a third or half the depth of scotia) to make it bend more or try steaming.
For the bathroom can you not fin plastic beading to match the shower tray that will be flexible enough.
Back to top
 Alert Moderators
LaminatePro
from United Kingdom
Thanked: 0 times
PostPosted: Thu Jul 02, 2009 8:34 pm    Post Subject:
With curved areas try undercutting and sliding laminate or wooden flooring underneath otherwise leave mdf beading soaking in water overnight this will make it flexible enough to go round corners.
As a side note most laminates do not work well in bathrooms though if it is just the shower tray that is the problem cut it neat to the tray and leave the gap at all other areas in the room.
Back to top
 Alert Moderators
mattysupra
from United Kingdom
Thanked: 5 times
PostPosted: Thu Jul 02, 2009 10:30 pm    Post Subject:
if you leave MDF beading in water over night, well dont it double its size?
Back to top
 Alert Moderators
LaminatePro
from United Kingdom
Thanked: 0 times
PostPosted: Fri Jul 03, 2009 6:20 am    Post Subject:
It will swell slightly but it doesn't make that much of a difference when it dry's back out in the shape that you are after. leaving beading standing upright for a few days will also put a curve on the beading.
Usually the best solution is to undercut as said above. fein or bosch both do great tools for this.
Back to top
 Alert Moderators
Richard C
from United Kingdom
Thanked: 48 times
PostPosted: Fri Jul 03, 2009 7:29 am    Post Subject:
I fitted the skirting over mine so that hid all but the bottom of the stairs where the last tread had a bull nose. Not sure if it will help in your case but I used a piece of white UPVC beading & bent the end around a 5 litre paint tin to form the radius; keep immersing it in boiling water to make it pliable & you can only bend it a bit at a time, holding the radius while it cools down. Takes time & you need to persevere but it works well & looks the part.
__________________
Richard C
Back to top
 Alert Moderators
Display posts from previous:
Post new topic   Reply to topic    DIYnot.com Forum Index > Floors, Stairs and Lofts All times are GMT
Page 1 of 1
Jump to:
Marking out a curve 5 3940 Mon Feb 19, 2007 12:15 am
mosai tile-cutting for a curve 4 8920 Mon Aug 30, 2004 3:08 am
Cutting Porceline Tiles Around a Round Mosiac 2 3960 Tue Mar 21, 2006 4:44 pm
Laminate flooring round toilet 2 2260 Wed Jan 26, 2005 10:48 pm
Scotias round laminate flooring - please help! 3 880 Mon May 17, 2004 12:54 pm
DIYnot
My DIYnot | Advertising | Newsletter
DIYnot.com | How to... | @home | Wiki | Forum
