DIYnot
Local | Network
   DIYnot > Forums
Local | Network
  Forum IndexForum Index     RulesRules    HelpHelp     Join FREERegister Free     BookmarksBookmarks     Watched TopicsWatched Topics     SearchSearch     LoginLogin
Radiator Valve Lip Snapped Off!!!!
This topic originated from the How to page called Fixing a leaking radiator
Click here to return to the page called Fixing a leaking radiator.
Post new topic   Reply to topic    DIYnot.com Forum Index > Plumbing and Central Heating
  View previous topic :: View next topic
Author Message
PlumbFun
from United Kingdom
Thanked: 0 times
PostPosted: Fri Jan 12, 2007 5:09 am    Post Subject:
Reply with quote Thanks
I was removing my radiator i went to turnt off one of the valves using grips to turn the lip on the valve and it snapped off i had to do this as there was no decorators caps on it.i do not know how i can turn this off now as it needs to be removed so i can get the room plastered please help
Back to top
 Alert Moderators
If you don't want to see this advert, click here to login or if you are new click here to join free.
nickso
from United Kingdom
Thanked: 21 times
PostPosted: Fri Jan 12, 2007 12:39 pm    Post Subject:
if you cant turn it off it probably means a new valve.
Back to top
 Alert Moderators
chr15
from United Kingdom
Thanked: 0 times
PostPosted: Fri Jan 12, 2007 12:44 pm    Post Subject:
Which means a system drain down or vacumn the vent and cold feed pipes in the f/e cistern.
Back to top
 Alert Moderators
Display posts from previous:
Post new topic   Reply to topic    DIYnot.com Forum Index > Plumbing and Central Heating All times are GMT
Page 1 of 1
Jump to:
valve snapped inside radiator bleeding key 5 1160 Tue Apr 17, 2007 6:33 pm
snapped gate valve on mains water inlet 9 2080 Fri Apr 20, 2007 2:34 pm
gate valve snapped in closed position 10 360 Tue Apr 21, 2009 8:43 pm
Snapped Screw!!!! 8 2260 Fri Nov 07, 2003 6:50 pm
Beaumont bath/shower Mixer lever snapped off 4 140 Mon Mar 09, 2009 10:32 pm
DIYnot
My DIYnot | Advertising | Newsletter
DIYnot.com | How to... | @home | Wiki | Forum
