DIYnot
Local | Network
   DIYnot > Forums
Local | Network
  Forum IndexForum Index     RulesRules    HelpHelp     Join FREERegister Free     BookmarksBookmarks     Watched TopicsWatched Topics     SearchSearch     LoginLogin
How do I replace cord on pull switch?
This topic originated from the How to page called Replacing a one way light switch
Click here to return to the page called Replacing a one way light switch.
  View previous topic :: View next topic
Author Message
lynbenson
from United Kingdom
Thanked: 0 times
PostPosted: Fri Jan 12, 2007 1:08 pm    Post Subject:
Reply with quote Thanks
The cord on the bathroom ceiling light snapped inside the fitting. I bought a new cord but can\\\'t see how it attaches. There is a hole for the cord to post into but then what do I do? Thanks.
Back to top
 Alert Moderators
If you don't want to see this advert, click here to login or if you are new click here to join free.
EddieCurrent
from United Kingdom
Thanked: 0 times
PostPosted: Fri Jan 12, 2007 2:11 pm    Post Subject:
Hello,
If the cord has broken inside the 'body' of the switch you will probably have to replace the switch itself.
__________________
I suppose I should add the fact that I am not a qualified electrician.
Back to top
 Alert Moderators
lynbenson
from United Kingdom
Thanked: 0 times
PostPosted: Fri Jan 12, 2007 3:13 pm    Post Subject:
I suspect that is the case. I took the red, black and copper wires out of the bits they are connected to and there is still no way to get inside, where the cord actually operates the switch.
Presumably a replacement will come with a cord attached and will connect those three wires into similar places? Getting someone out for something so small is quite impossible.
Back to top
 Alert Moderators
Steve
from United Kingdom
Thanked: 21 times
PostPosted: Fri Jan 12, 2007 3:36 pm    Post Subject:
yeah, just buy a 1-way, single pole, 5 amp or 10 amp pull-cord switch. The 3 terminals should be marked L1, COM and earth, or similar.
Back to top
 Alert Moderators
Display posts from previous:
Page 1 of 1
Jump to:
How to replace my bathroom pull cord switch? 5 440 Sat Apr 05, 2008 10:26 am
Replace power cord on Hedge Trimmer 3 380 Thu Apr 15, 2004 3:23 pm
pull cord switch 6 13940 Mon Nov 24, 2003 2:46 pm
Pull Cord Switch Connections? 2 340 Fri Feb 23, 2007 1:46 pm
pull cord light switch won't click 2 3540 Mon Dec 01, 2003 6:51 pm
DIYnot
My DIYnot | Advertising | Newsletter
DIYnot.com | How to... | @home | Wiki | Forum
