Potterton 80 e not working!
9 Mar 2004
have a potterton 80e which has had main circuit board replaced and worked for two months. it will not light when you request heat or water, it just goes ito lock out! Any ideas? ( the piazo crystal thingy doesnt even spark! any help apreciated as its cold in here1
just read your problem with your potterton puma 80e boiler locking out. We are having the same problem with ours it just locks out whenever we try to put the boiler on. Four heating engineers can find no problem and we just wondered if you ever got to the bottom of it and if you could give us some much needed advice!!!!
jetskim wrote that a month ago and has not been back since (check date and number of posts)
I too have a potty combi, locking out quite often, new pcb sorted it for a while, then started again, turned out pump impellar smashed
