ADDITIONAL RADIATOR
L
longdogs
Hi
I would like to add a new small radiator to a cloakroom about six feet away from the nearest existing radiator. The floor is concrete and the house is chalet style which means it is impossible to get flow and return pipes coming into room from above or from below.
My question is: Is it feasible to connect the new rad to the flow and return pipe coming up from the floor to the existing rad? ie, teeing off just under the valves?
Many thanks.
kevplumb said:
size of rad is :?:
size of pipework is :idea:
size of rad you are proposing to fit is :?:
Size of rad: 1200x600 single
Size of pipe work: 15mm
Size of new rad: 600x600 single
