I am building an extension to my house and will be adding a new ring main for internal, ring main for garden (sheds, etc.), lighting internal and lighting external. I wish to connect these to a new consumer unit as my 6-way unit is full. My question is this - can I take a feed from an MCB in my current unit (I will need to disconnect the boiler) to the new unit (boiler will be moved to this), or will I have to connect new tails from the in-feed of the existing unit to the in-feed of the new unit? If the latter, how do I do this safely with the mains fuses in place (if I remove them the tamper seals are broken)? replacing the 6-way unit for a 10 or 12-way unit is not really possible due to space limitations (the new consumer unit will be fitted to the opposite wall in the understairs cupboard).
