DIYnot
Local | Network
   DIYnot > Forums
Local | Network
fitting wooden beads
Post new topic   Reply to topic    DIYnot.com Forum Index > Windows and Doors
Author Message
pegasis
from United Kingdom
PostPosted: Mon Jan 15, 2007 9:42 pm Reply with quote
What is the best way to fit wooden beads when glazing a wooden frame window.
Is it best to put glazing tape on both sides of the bead that come into contact with the glass and the window frame, or is glazing tape on the glass side of the bead sufficient?
Also what is the best type of tape to use for this job. I've seen foam tape,double sided foam tape, butyl tape but am not sure which would be best.
thank in advance.
Mark
Back to top
 Alert Moderators
masona
from United Kingdom
Thanked: 117 times
PostPosted: Tue Jan 16, 2007 4:06 pm Reply with quote
Which side is the beading, internal or external?
Back to top
 Alert Moderators
pegasis
from United Kingdom
PostPosted: Thu Jan 18, 2007 6:49 pm Reply with quote
its for external beading
Back to top
 Alert Moderators
pegasis
from United Kingdom
PostPosted: Fri Jan 26, 2007 10:46 pm Reply with quote
No one know this?
I need to have a look at a wooden window and see for myself really. I suppose the tape will only go on the glass side and maybe just some silicon down the other side of the bead before securing?
Back to top
 Alert Moderators
Forest Grump
from United Kingdom
PostPosted: Sat Jan 27, 2007 12:19 am Reply with quote
I would put a bead of clear silicon around the frame, bed the glass in it, put another bead of silicon around the glass, then fit the wooden beads with panel pins.
Back to top
 Alert Moderators
masona
from United Kingdom
Thanked: 117 times
PostPosted: Sat Jan 27, 2007 12:53 pm Reply with quote
Or use putty on the inside with glazing tape on the outside, the problem with glazing tape, they are a b*****r to get off if need be.
Back to top
 Alert Moderators
pegasis
from United Kingdom
PostPosted: Mon Jan 29, 2007 9:55 am Reply with quote
Thanks for the responses guys.
What is the best type of tape to use thats a decent quality but not overly expensive. Its for some windows on a shed and possibly a 15'greenhouse with large panels, so it doesnt have to be great quality stuff.
Mark
Back to top
 Alert Moderators
masona
from United Kingdom
Thanked: 117 times
PostPosted: Mon Jan 29, 2007 12:28 pm Reply with quote
Got mine from here
I think it was called Security Glazing Tape, did 90 panes of glass for my summerhouse icon_exclaim.gif
The price was reasonable but the downside was 10 delivery.
Best to give them a ring to find out which one is suitable for yours
Back to top
 Alert Moderators
pegasis
from United Kingdom
PostPosted: Mon Jan 29, 2007 8:27 pm Reply with quote
Thanks for that info masona.
Did you fit the glass in your summerhouse using putty on the inside and glazing tape on both edges of the beading? ie glass and window frame outside?
Back to top
 Alert Moderators
masona
from United Kingdom
Thanked: 117 times
PostPosted: Tue Jan 30, 2007 11:54 am Reply with quote
My beading was on the inside, so I use the glazing tape on the rebate then push the glass onto the glazing tape (must line it up every time, I've used a matchstick on the bottom of the glass to helped me to line it up, if you don't the swearing kicked in icon_wink.gif ) then just put in the wooden beading in as it is because the outside is now waterproof. Important that the glazing tape have no corner gaps otherwise water will get in although there's nothing to stop you running a small clear sealant round the glass.
Back to top
 Alert Moderators
pegasis
from United Kingdom
PostPosted: Tue Jan 30, 2007 2:24 pm Reply with quote
Thanks for that info. Certainly makes more sense to have the beading on the inside, makes fitting the glass less hassle even tho I never thought of it:)
Will hopefully save a bit of time and make a better job on the greenhouse.
Mark
Back to top
 Alert Moderators
joatex
from United Kingdom
PostPosted: Mon Feb 12, 2007 7:41 am Reply with quote
Masona why is the beading usually outside ? It seems that if was inside that would avoid the need for drainage channels in the beading or capillary tubes in the rail. It seems to be so sensible that I must have missed the real reason.
Back to top
 Alert Moderators
masona
from United Kingdom
Thanked: 117 times
PostPosted: Mon Feb 12, 2007 11:18 am Reply with quote
Back to top
 Alert Moderators
joatex
from United Kingdom
PostPosted: Tue Feb 13, 2007 8:58 pm Reply with quote
Masona I was thinking about DG casement wooden windows in general. Putty is no longer used to seal the glass to the rail etc. So if the glass was placed from inside and sealed against the wood by tape. The beading can now placed inside. That would reduce the number of individual pieces of wood exposed to weathering. And no need for scaffolds for the upper story windows
Back to top
 Alert Moderators
masona
from United Kingdom
Thanked: 117 times
PostPosted: Wed Feb 14, 2007 11:33 am Reply with quote
That's correct, we was talking about single glass on summerhouse/greenhouse etc icon_wink.gif
Back to top
 Alert Moderators
Post new topic   Reply to topic    DIYnot.com Forum Index > Windows and Doors All times are GMT
Page 1 of 1
Jump to:
fitting beads on upvc window 3 840 Fri Oct 16, 2009 12:06 am
Removable Staff Beads on sash windows 2 460 Wed Aug 04, 2010 12:38 pm
very tight glazing bars/ beads 4 700 Sun Jan 24, 2010 11:23 am
removing aluminium window glazing beads 2 680 Wed Dec 17, 2008 11:20 pm
tool for removing beads on upvc windows 4 1980 Wed Aug 22, 2007 2:43 pm
DIYnot
Please read our Privacy Policy. Copyright © 2000-2015 DIYnot Limited.
